Hardwood Staples Never Go In All The Way -- Need Setting - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2014, 07:25 PM   #1
Rewards Points: 1,062
Question
Hardwood staples never go in all the way -- need setting
I just started installing my hardwood floor and got past the first few rows that require vertical nailing so that the hardwood nailer can fit.
However, one thing that's annoying is that staples NEVER go in all the way into the groove, instead they are sticking just enough for the top to be touching the upper rail above the groove. So I need to set them manually, which works but is slow as hell.
Is there a possibility that I am doing something wrong? I am using a NuMax nailer, which got high reviews on Amazon. Could it be that the setting depth on the nailer is set to not go deep enough? I am using the proper shoe pad on the nailer that matches my flooring thickness (3/4").
Old 03-10-2014, 07:31 PM   #2
woodman58's Avatar
Try turning the pressure up on the compressor. It should be between 90 and 100PSI for most nailers. If that does not work then there is something wrong with the nailer.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
oh'mike (03-10-2014)
Old 03-10-2014, 08:12 PM   #3
the air pressure was fine
Old 03-10-2014, 09:08 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
If the shoe is right, then the pressure is too low. How do you know the pressure is "fine"?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 03-10-2014, 09:27 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 9,346
I've seen pressure gauges that were 20-30 PSI off.
I used a HF nailer.....I adjusted the air pressure until I got the depth I wanted.
For reference...that same air pressure was not enough for my brad nailer....
Old 03-10-2014, 09:28 PM   #6
The gauge on the compressor. Now, if something impedes the pressure inside the gun, that's within the gun. I tried blowing through the hose to see if there may be something that clogs it but that too was fine.
Old 03-10-2014, 09:30 PM   #7
The same air compressor pressure has no problem nailing a 3" framing nail into a 2x4. I don't see why it would have problem driving a teeny staple into hardwood. Unless it is for the hardness of the lumber.
Old 03-10-2014, 09:41 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
What kind of hardwood?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-10-2014, 09:43 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 750
Ya think??
Doesn't the compressor have a regulator with a pressure gage, along with the tank's pressure gage? You been oiling the gun?
Jaz
Old 03-10-2014, 10:38 PM   #10
Maple
Old 03-10-2014, 10:41 PM   #11
the regulator don't really do much when i turn the knob but the compressor pumps up to about 115 psi max. The gun is brand new and I did lube the s*it out of it before plugging it in for the first time.
Old 03-10-2014, 10:48 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 750
The tank's gage is always gonna go to near 120 psi. That gage tells you nothing in regards to how much pressure you're delivering to the gun. The last dial, the one regulated by the regulator is the only you adjust. If it just turns, it means you didn't pull the knob out so it'll do something. They're not all the same, my first one didn't need pulling out, the one I have now does. What does the last dial say?
Jaz
Old 03-10-2014, 11:41 PM   #13
You may also have a dial on the gun to adjust depth.
MissKat is offline   Reply With Quote
Old 03-11-2014, 07:38 AM   #14
Not so new
12penny's Avatar
Rewards Points: 522
Hmmm....might be me. I'm off today with a cold and have a little Nyquil in my system so I could be missing something, but I normally nail the tongue and not the groove. Just me? I've been doing it wrong all this time?
12penny is online now   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
amakarevic (03-11-2014)
Old 03-11-2014, 08:00 AM   #15
woodman58's Avatar
I did not catch that. If he is nailing into the grove instead of the tongue, that is a big problem. I have talk to people trying to install hardwood the wrong way. (Into the grove)
Tags
hardwood
Aren't 1-1/2" staples too long for 3/4" hardwood flooring? amakarevic Flooring 4 03-10-2014 03:34 PM
What size staples for 3/4" x 2-1/4" maple hardwood? amakarevic Flooring 8 01-07-2014 06:16 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4" hardwood: staples or nails johngeorge Flooring 5 03-04-2012 07:13 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
