Hardwood Stair Tread Trim Or Part Of Tread? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2014, 03:39 PM   #1
Rewards Points: 51
Hardwood stair tread trim or part of tread?
We are expecting our 1st baby and I added carpet stair treads to reduce slipping. There is a little lip on the stair tread, can I remove? gf wants carpet but if I get rid of the raised lip so tread it's flat might be OK.
Slammed01 is offline   Reply With Quote
Old 09-22-2014, 04:19 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 17,684
Nice looking dogs.
By lip, do you mean at the edge of the tread? If so, no, you can't remove them. Nor do you want to.
I believe you want to do something like this? You use the carpet rod to hold the bottom snug and the top just gets nailed to the stair tread
ddawg16 is online now   Reply With Quote
Old 09-22-2014, 04:21 PM   #3
Rewards Points: 51
Yes the edge of the thread as its raised a good 1/4" to 1/2"...no way to replace so stair tread is flush and even? We were thinking about doing all carpeted stairs
Old 09-22-2014, 04:24 PM   #4
Rewards Points: 144
Even with all carpet they will leave the bullnose on the tread.
mako1 is offline   Reply With Quote
Old 09-22-2014, 04:25 PM   #5
Rewards Points: 51
Right but you will still feel it and be a potential problem I would think? Only option is to redo all stairs? Or do carpet over with nose?
Old 09-22-2014, 04:31 PM   #6
JOATMON
ddawg16's Avatar
Carpet over the nose as in the pics....
And you have to keep the tread nose....
Believe me, you don't want to take them off
Old 09-22-2014, 04:33 PM   #7
Rewards Points: 144
Stairs have been that way for hundreds of years.Has your GF never used stairs before? Don't mean to be a dick,but?
The nosing can be cut off and some is glued on to the tread as a separate piece.
By taking it off your stairs may not conform to your local building code.
Old 09-22-2014, 04:36 PM   #8
Rewards Points: 51
I'm not worried about the nose that hangs over risers, it's the bump,/raise that's under the carpeted stair tread. Not all stairs have that.... Right where the pits paw is you can see the difference in carpet
Old 09-22-2014, 04:39 PM   #9
JOATMON
ddawg16's Avatar
I bet Kwickfish would think his Stair Code would get so much attention so soon...
Here is the code snippet...
Old 09-22-2014, 04:42 PM   #10
JOATMON
ddawg16's Avatar
Oh....you mean the 1/4 round put in at the base of the riser to hide the gap in the wood when it was put in?
The same 1/4" round that is used to hide sloppy work?
Yes, you can remove it...especially if you do carpet runners.
Old 09-22-2014, 04:44 PM   #11
Rewards Points: 51
Yea I'd say more like 1/2" sorry I was unclear.... Bought the house with stairs done.
Old 09-22-2014, 04:50 PM   #12
Rewards Points: 51
The pits right paw, see the raise on the middle of tread? That
Old 09-22-2014, 04:54 PM   #13
JOATMON
ddawg16's Avatar
All I see is the carpet lifting up on that one side.
I'm guessing the carpet pads were glued down?
Yes, you can remove....but I think you're going to have a lot of glue to remove.
Old 09-22-2014, 04:55 PM   #14
Rewards Points: 144
Sorry for the misunderstanding.It was not clear from the pics or your text.Yes,Those can be taken out with no problem.
Old 09-22-2014, 04:58 PM   #15
Rewards Points: 51
No I used velcro, that's the Difference in height from the Bull nose to tread and I used the carpet to cover. Is that normal?
Replacing stair tread on closed stringer stairs... J187 Carpentry 11 01-16-2017 07:24 PM
Question about stair tread height bkanneg Building & Construction 13 08-17-2016 10:16 PM
TREX decking for stair tread question ryan5068 Landscaping & Lawn Care 5 06-18-2013 09:40 AM
repair/refinish just part of hardwood floor area? denemante Flooring 1 10-03-2011 11:43 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
