Hardwood Salvage Recommendations.... - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2015, 10:10 PM   #1
hardwood salvage recommendations....
I was given a large load of white maple hardwood flooring, used. Every piece has staples in it. The hardwood is in very nice condition, 3/4" th., and approx. 2" in width. lengths are from 1' to approx. 6+ ft. What are your recommendations for removing the staples, with a minimum of damage to the tongue? The penetration into the tongue is good, and not showing the staple head on the tongue surface. My thoughts are to use a Dremel tool w/ a cutoff. wheel. Time consuming, but should give the desired outcome of not damaging the tongue. The time is available to go this route. Pictures show the staples. The pic w/ the large amount of flooring only shows about 1/3 of the amount I picked up. So, there's plenty to do my job. Thanks, David.
hardwood salvage recommendations....-white-maple-hardwood-used-001.jpg   hardwood salvage recommendations....-white-maple-hardwood-used-004.jpg   hardwood salvage recommendations....-white-maple-hardwood-used-006.jpg
edselsouth1 is offline   Reply With Quote
Old 05-04-2015, 10:28 PM   #2
Rewards Points: 1,760
Dremel would be slow and frustrating and cost you dozens of those little cutoff bits. If you have a compressor, pick up an air-powered cutoff tool, they are pretty cheap and will make fast work of those staples.
ChuckF. is offline   Reply With Quote
Old 05-04-2015, 11:15 PM   #3
Hardwood salvage....
ChuckF........... I have a small air powered grinder, and a small Bostitch air compressor. Might be enough. I also have an electric angle grinder, 4-1/2" size. One or the other should do it! Thanks for the suggestion.
The Following User Says Thank You to edselsouth1 For This Useful Post:
joecaption (05-05-2015)
Old 05-05-2015, 07:47 PM   #4
Rewards Points: 1,042
Air power tools use a tremendous amount of air.
Canarywood1 is offline   Reply With Quote
Old 05-05-2015, 08:35 PM   #5
Property Mgt/Maint
Rewards Points: 6,564
snip off the staple legs with a pair of dykes close as you can, then smooth off the stubs with your right angle grinder and a 60 grit resin fiber disc, probably take less than 10 seconds per staple
[political signature removed]
Yodaman is offline   Reply With Quote
Old 05-05-2015, 11:01 PM   #6
Flooring salvage....
Canarywood1..... I'm going to try the Bostitch compressor, and see what it does. Worst case, have to go to plan #2 ....or 3....
Yodaman..... Thanks for the suggestion. One of the suggested ideas will for sure work.
Hardwood Flooring Product Recommendations brandofaction Flooring 18 05-15-2014 12:50 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
