Hardwood Floors Over Particleboard - Flooring - DIY Chatroom Home Improvement Forum
Old 12-30-2015, 12:09 AM   #1
Rewards Points: 43
hardwood floors over particleboard
I've read various articles on this topic however non ever seemed to directly apply to my situation. Thought I'd ask the community.
Our 1977 ranch has 3/4" particle board over 1/2" plywood subfloors. The interior walls of the house are on top of both layers. I'd like to install 3/4" thick hardwood floors. I was going to remove the particle board layer but then discovered the interior walls were on top of it when I removed the baseboards.
Instead I'm thinking to add a 1/2" layer over the particle board, then screwing all layers down with 2 1/2" screws. Just seeing if this is adequate, or if there are any other suggestions. Any and all comments are appreciated. Thank you for reading.
jobblyman is offline   Reply With Quote
Old 12-30-2015, 09:11 AM   #2
Rewards Points: 247
Nails, staples, etc. have no holding power in particle board, particle board does not help to stiffen the floor, and swells when exposed to water. I'd get a toe kick saw to cut the particle board flush with the walls and then rip it all out, pray hard that the builder didn't glue it down like in my house.
chemman is offline   Reply With Quote
Old 12-30-2015, 09:25 AM   #3
Rewards Points: 5,348
Can you post a photo of the particle board?
Ron
B. Franklin 1759
Old 12-30-2015, 09:33 AM   #4
Rewards Points: 43
Sure I can posts pictures later this evening. However I am confident it is particle board. It looks like this...
http://1.bp.blogspot.com/-taTP6ajM--...icle+Board.jpg
I did think of the toe kick saw idea. I then read the installation procedures for the flooring and it said if particle board is the subfloor surface cover with a minimum 3/8" plywood underlayment. I was going to use 1/2" so it would match the tile backer to be installed for the flooring in the bathrooms.
Luckily under the bathrooms and kitchen they have 3/4" plywood on top of 1/2" plywood. They used particle board in the rooms with carpet installed.
Old 12-30-2015, 10:05 AM   #5
That photo is certainly particle board. One of the more useless building materials ever produced.
Ron
B. Franklin 1759
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 12:20 PM
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 06:05 PM
Old school hardwood floors Joe Tilghman Flooring 6 02-24-2012 07:46 PM
Direction of hardwood floors DBounlom Flooring 2 10-08-2011 07:37 PM
tile over hardwood floors MnMan Flooring 1 07-30-2008 06:39 PM
