Hardwood Floor Under-layment - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2019, 02:50 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,876
Hardwood floor under-layment
I went through the painstaking task with my existing hardwood floors of uninstalling, de-nailing, scraping 90 years of yuck stuck between the boards, and finally planing off the finish. My house has been undergoing an extensive renovation and the boards have been piled up for a couple/few years now.
This weekend I'm going to start re-installing them.
When I pulled them up they were nailed directly to the plank subfloor with no underlayment. I've pulled the planks up and installed a plywood subfloor.
Do I need an underlayment if the space below is conditioned? If so, what products are available for underlayment?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-16-2019, 06:56 PM   #2
I have gas!
Re: Hardwood floor under-layment
Stumbled across a roll of rosin paper. I forgot a friend had given me his leftover. That will work, right?
Old 04-18-2019, 05:59 AM   #3
Rewards Points: 2,608
Rosin paper is the usual choice. If your subfloor is rough (relatively), I would consider using 30 lb tarpaper.
carpdad is offline   Reply With Quote
Old 04-18-2019, 06:07 AM   #4
retired painter
Rewards Points: 1,790
Locally, 15lb roofing felt is the norm under hardwood.
mark sr is online now   Reply With Quote
Old 04-19-2019, 09:47 AM   #5
I have gas!
Thanks, I'm going to use up the rosin paper. I haven't decide on heating method yet and retrofit radiant floor is one of the options; I don't want any issues with off-gassing of tarpaper.
New hardwood flooring install advice RetroJoe_1 Flooring 2 02-25-2019 09:18 AM
Matching solid hardwood h22lude Flooring 8 11-23-2014 09:58 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
