Hardwood Floor Pattern - Different Plank Length - Flooring - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 02:30 PM   #1
Hardwood floor pattern - different plank length
When we installed engineered wood floor, they come in 3 different lengths. We had a hard time trying to arrange it so that the pattern looks good.
Now, we are installing hardwood floor which comes in 5 (if not 6) different length. We will be --for sure -- headache with this .
I keep telling myself, there must be a standard way of doing this. I tried to search everywhere, but I couldn't find any detail (may be bad keyword?). Can anyone point me to the right direction?
thone is offline   Reply With Quote
Old 07-25-2011, 02:43 PM   #2
Experienced
Jackofall1's Avatar
Rewards Points: 2,102
I am guessing you are laying a prefinished floor.
The pattern is completely random, in fact the more random the better. Keep you connections a minimum of 6" apart.
I'll bet you have alot more short pieces than long. Open at least 3 boxes and set the pieces against the wall by order of length, you will have to keep in mind that you have to use up the shorts at a faster rate than the longer pieces.
I just finished laying a whole house (5 rooms) worth turned out looking rather good, hope you have help, it sure make it go easier, make sure you leave the recommended gaps between fixed objects and floor. The real challenge is keeping everything straight especially on the long runs like a hallway.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
thone (07-27-2011)
Old 07-26-2011, 09:02 PM   #3
Never too old to learn
Dudester60's Avatar
Just a quick high jack question....is it better to nail new hardwood flooring 'across' the joists, or parallel ?
Dudester60 is offline   Reply With Quote
Old 07-27-2011, 09:38 AM   #4
Experienced
Jackofall1's Avatar
Manufacturers recommend that the floor planking be laid perpendicular to the floor joist this will provide the best results for stability for the life of the floor.
Mark
Old 07-27-2011, 02:16 PM   #5
Rewards Points: 5,348
If your subfloor is individual boards(as opposed to plywood) you lay the finished floor perpendicular to the subfloor.
Ron
B. Franklin 1759
Old 09-11-2011, 10:37 AM   #6
Dudester60's Avatar
I have " plywood over the joists which are 12" center. For cosmetic reasons, I'm going to take a chance and nail parallel to the floor joists....if I go perpendicular, my hallway will look like a rail road track. I'll be doing a transition through the doorways into 3 bedrooms. Using " prefinished maple stained bronze, 3" wide. Got about 500 sq ft to do.
Old 09-11-2011, 12:01 PM   #7
Rewards Points: 200
try and keep your end joints at least a foot apart from the next board , and at least two board over .
Floor Doc is offline   Reply With Quote
Old 09-11-2011, 02:00 PM   #8
I'd lay it out on the floor first to see what it looks like. The long way is the traditional layout format. I've never laid a floor or seen one laid the short way.
Ron
B. Franklin 1759
Old 09-11-2011, 04:37 PM   #9
Dudester60's Avatar
Yup. I already did lay them out sideways and it looks like a rail road track...not cosmetically soothing to the eyes....hence why I'd like to go on the length. My hall way is straight, and I wouldn't even have to rip the last board, cause it fits perfectly with the allowable " gap on each side. The tricky part will be going from the hallway into the 3 bedrooms, (2 on the right, and one on the left side of the hallway) Will have to make a spline for the left side, in order to change direction and work into that room. I will definitely keep the joints minimum a foot apart or more, thanks for the tip. Wish me luck......I'm going to need it !!!
Once I'm done I'll upload some pics, but don't expect that to happen for another couple of weeks. lol.
oiled wood engineered wide plank hardwood floor david cohen Flooring 1 06-12-2011 10:04 PM
Hardwood floor parallel with plank subfloor acerunner Flooring 4 06-08-2011 09:35 PM
Diagonal plank subfloor preparation for Hardwood Flooring? Fingers Flooring 3 11-26-2009 12:03 PM
New Hardwood over Plank Flooring christianjl Flooring 1 08-24-2009 06:51 AM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 06:38 PM
