Hardwood Floor Height Adjustment? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2016, 09:39 PM   #1
ZZZZZ's Avatar
Rewards Points: 1,338
Hardwood floor height adjustment?
I'm getting ready to re-do all the flooring on my first floor. The kitchen and the foyer/mudroom will be tiled and the hallway, dining room and great room will be a floating installation of engineered hardwood.
This is a "standard" installation over 2x8 16" OC floor joists and 7/8" T&G OSB subfloor. (Not sure of the official thickness of the OSB, but that's what it measures in the floor openings for the heat registers. It's a 28 year old house.)
(I've already dealt with the tile deflection issue by adding a supporting beam below the joists.)
I'm estimating the height of the tiled floor to be: 1/4" tile plus 1/4" backerboard plus two 1/8" layers of thinset to be a total right about 3/4".
The hardwood is 1/2" and the underlayment padding is 1/8" for total 5/8".
It is an open floor plan, and there will be about 10 linear feet where the tile will meet the hardwood.
My question is how to handle the 1/8" difference. What are my options? Would adding a second layer of underlayment make sense? (I'd guess no.) Or lay down some kind of 1/8" plywood? Or just install transition strips? Or is a 1/8" height difference even a tripping hazard that has to be dealt with?
Any advice would be appreciated. Thanks.
ZZZZZ is online now   Reply With Quote
Old 03-04-2016, 09:57 AM   #2
JUSTA MEMBER
Rewards Points: 1,658
In my opinion a 1/8 inch difference is a trip hazard.
I trip over a stupid piece of vinyl flooring that is used to just cover a burn mark in a frequented place.
Can you get a 3/8 inch backer instead, or maybe use a luan ply over the entire subfloor for this area.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
ZZZZZ (03-04-2016)
Old 03-04-2016, 06:57 PM   #3
Tony_G's Avatar
Rewards Points: 48
Not too long ago I completed a similar installation and ended up using 5 mm panels to level the floors. This obviously increases the cost of your project.
Do you have the hardwood already? Is going with a 3/4 inch one an option at this point? Although I'm assuming you do not want to deal with nails/staples?
Tony_G is offline   Reply With Quote
The Following User Says Thank You to Tony_G For This Useful Post:
ZZZZZ (03-04-2016)
Old 03-04-2016, 07:15 PM   #4
ZZZZZ's Avatar
Yes, I already have the hardwood.
I am going to lay the tiles first, since they will be taller. Then I can see exactly what the finished height will be. Than I can decide what to do for the hardwood.
I forgot to mention that I will be putting down slate tile, and the tile varies in height a bit from piece to piece, so maybe I can save the thinner pieces for the edges where it will meet the hardwood.
Yeah, I'm not sure if laying down 1/8" plywood over the half the floor is worth the time and money vs. coming up with some kind of transition solution. Or maybe I will just leave a small gap between the tile and wood and fill it with caulk that matches the tile grout.
Old 03-04-2016, 07:28 PM   #5
Retired Moderator
Rewards Points: 7,174
Fine tuning the height can be accomplished using layers of felt paper (tar paper)
You will need a T- molding over the edge of the floating floor--so the height difference might not be an issue.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
asevereid (03-04-2016), ZZZZZ (03-04-2016)
Old 03-04-2016, 10:44 PM   #6
Rewards Points: 1,680
With the t strip between the two it shouldn't be an issue. Or take a look at ditra as opposed to the backer board and save 1/8". Ron
ront02769 is offline   Reply With Quote
Matching solid hardwood h22lude Flooring 8 11-23-2014 10:58 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
