Hardwood Floor Condition - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By SeniorSitizen
  • 1 Post By Nealtw
Old 11-01-2017, 11:20 PM   #1
Rewards Points: 52
Hardwood floor condition
Hi. Can people opine on the condition of the floors - decent, bad, good enough? I will be listing house for sale and want to know if I need refinishing, replacing, or light buffing.
I do not like the gaps between the planks. May not be easy to tell from pictures but there are gorges, scratches, dings, dents. What's the moist cost effective way to fix?
Sent from my SM-G930P using Tapatalk
nytimes770 is offline   Reply With Quote
Old 11-02-2017, 03:49 AM   #2
Rewards Points: 3,209
There is an awesome product called Rejuvenate Wood Floor Professional Restorer. You wipe it on and scratches disappear. It has saved my butt a few times when I was moving ladders and furniture around in a customer's house for painting.
To get rid of deep gouges, you have to sand. Gaps between boards can't really be fixed. If you try filling them, it will look horrible and can cause buckling. You need a new floor.
I'd wipe it with Rejuvenate and call it good.
mathmonger is offline   Reply With Quote
Old 11-02-2017, 05:19 AM   #3
retired painter
Rewards Points: 80
Re: Hardwood floor condition
If the wood is stable you can use a filler between the boards BUT that is something you'd do in conjunction with sanding the floor down for a complete refinish job.
IMO the floor looks decent and I wouldn't do anything other than clean/wax - maybe use the rejuvenate stuff.
mark sr is online now   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
nytimes770 (11-02-2017)
Old 11-02-2017, 11:25 AM   #4
Dave Sal's Avatar
Rewards Points: 648
I think the floor looks really good.
Dave Sal is offline   Reply With Quote
Old 11-02-2017, 11:34 AM   #5
Rewards Points: 6,554
If the floor is well within the parameters of the condition of the remainder of the property I wouldn't touch it.
ChuckF. and Nealtw like this.
Old 11-02-2017, 12:00 PM   #6
retired framer
Rewards Points: 15,658
I agree with @SeniorSitizen , the floor would be good in any house I have lived in but it might not be good enough for a high end castle.
SeniorSitizen likes this.
Old 11-03-2017, 08:27 PM   #7
Rewards Points: 6,146
I would try some Johnson non-slip floor wax first.
Sweep and clean the floor.
When dry, buff.
If that doesn't work then..................
ron45 is online now   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
