Grout, Sanded Caulk, Or Both? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-13-2013, 12:27 PM   #1
Dave88LX's Avatar
Rewards Points: 796
Grout, sanded caulk, or both?
Questions in area are pictured below. Would I use grout for the whole thing, or use the sanded caulk in any of these areas? These are the products I have:
Would I be better off painting the riser then grout/caulk, or, doing the painting afterwards? I also need to install my base trim...before or after grout?
Front door threshold:
First stair riser:
There is a wood nosing going here with a grout gap line the same as the others.
Dave88LX is offline   Reply With Quote
Old 11-13-2013, 04:55 PM   #2
Rewards Points: 18,074
Any place tile changes direction or meets a different material you use caulking not grout.
Dave88LX (11-14-2013)
Old 11-13-2013, 04:59 PM   #3
Dave88LX's Avatar
Rewards Points: 796
Thanks Joe. Should I caulk or grout first?
Old 11-13-2013, 06:36 PM   #4
Retired Moderator
Rewards Points: 7,174
I usually grout first---Then caulk---
I have heard of caulking first---so it must work for some people---but I believe it is easier to caulk last.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Dave88LX (11-14-2013), JetSwet (11-13-2013)
Old 11-14-2013, 08:38 PM   #5
Dave88LX's Avatar
Rewards Points: 796
Gotcha, thank you! First time grouting. This is going to suck I think.
Old 11-15-2013, 08:31 AM   #6
Retired Moderator
I wrote up a nice how to on grouting---look for jimf--downstairs bath or Big Jims--thread about 'large tiles'--I'm off to work----so you or someone else will need to dig it up----
Old 11-15-2013, 08:55 AM   #7
Make sure to clean up when your done.
It's a whole lot harder to get off once it's dried.
Old 11-15-2013, 10:45 AM   #8
Dave88LX's Avatar
Rewards Points: 796
Gotcha Mike, I will do a search for it.
Joe -- You're right. I wish I did a better job cleaning up the thinset when it was still wet.
Old 11-15-2013, 06:29 PM   #9
Retired Moderator
Here is a post from Jim Fs bathroom remodel---
Jim's downstairs bathroom project
Jim, The grout that you have chosen is a good one---Mix with cold clean water --about the consistancy of yellow mustard--
You don't want to do any of the water spraying goofyness--I suggest that ,as a novice, you do one wall at a time.--Use a soft white grout float--the disposable black sponge rubber ones tend to dig into the cracks and cause frustration.
Go back and forth several times and really pack the joints full--use the float like a squeegee--on an angle to the joints,to remove as much excess as you can--
Go have a small cup of coffee-----give the grout 10 to 15 minutes to set a little---
Then start the first 'break'(cleaning)--You will want to have 2 or 3 grout sponges and a couple of buckets of clean water---
The first break is to shape the joints and remove the majority of the excess grout---
Ring out your sponges almost dry--start cleaning using a gentle circular motion---don't try to actually clean the surface with the first break---just shape the joints and remove the majority from the face of the tile------You will probably only get 4 to 9 tiles before you need to flip the sponge---
Second break----no coffee this time--clean water --ring out the sponges almost dry--
All that should be on the tiles at this point is a messy smear---start wiping on a diagonal--
press the sponge flat with both hands and slowly pull the sponge and roll it as you pull --
You should get about 12 inches wiped before you flip the sponge and --press -slowly pull and roll up.
Final cleaning---at this point all that should be on the face of the tile is haze and a lot of small streaks---You can have another cup of coffee----Wait about 15 minutes--
Final wipe--if done correctly--the tile should (had better be) be clean and shiny--done except for the tiniest bit of streaks.
This time --go with the tiles,not diagonally--two hands on the sponge- press-pull and roll only about 12 inches --then flip the sponge and do another 12 inches--rinse ring dry and repeat--Most beginners try to get to much cleaning out of a dirty sponge--Any one who has wiped up a glob of jelly knows the press and roll of the sponge----Good luck--Mike-- ___________
Old 11-18-2013, 01:26 PM   #10
Dave88LX's Avatar
Rewards Points: 796
Thanks for the detailed write-up Mike. I don't eat jelly, mustard, or drink coffee...what do I do now?
All makes sense, 'wiping up jelly', that's good.
The Following User Says Thank You to Dave88LX For This Useful Post:
oh'mike (11-19-2013)
Old 11-19-2013, 07:03 PM   #11
Retired Moderator
I use epoxy grout for most jobs---That product is great,but totally unforgiving---
Old 11-22-2013, 09:02 PM   #12
Dave88LX's Avatar
Rewards Points: 796
Well it went much much better than I had expected. I think I need to wipe it down a couple more times to get the haze off, but it's basically clean. I was concerned about getting the grout lines to look right, or the grout pulling out as the sponge wiped over them. No issues.
I did however end up with 2 blisters I've never gotten in all my life before, right in the middle of my palm.
Thanks for all the help! I have some grout sealer I assume I should put on there too....
Old 11-22-2013, 10:04 PM   #13
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Yeah, don't go to bed until it is as clean as you're ever going to want it. Any haze left overnight will basically turn into cement.
If you have a microfiber cleaning cloth on hand they work great for the final wipe down.
Old 11-22-2013, 10:36 PM   #14
Dave88LX's Avatar
Rewards Points: 796
No worries about continually skimming the grout with a moist sponge?
Didn't realize it would do that. I'll hit it a couple more times after I eat then. I figured the haze would rub off. (Barely noticeable at this point)
Old 11-22-2013, 10:44 PM   #15
Rewards Points: 206
At this point just buff with a microfiber or lint free towel. A moist sponge will keep putting the haze back on the tile.
Dan
djlandkpl is offline   Reply With Quote
1x1" glass tile disaster, installer used sanded grout! Btw55 Tiling, ceramics, marble 3 11-04-2013 08:58 PM
can i caulk over grout? dooo42 Tiling, ceramics, marble 1 07-02-2011 08:19 PM
Using sanded grout for spaces less than 1/8"? sukhenkoi Kitchen & Bath Remodeling 7 05-20-2011 05:51 PM
Can I use sanded grout for wal tiles? sukhenkoi Kitchen & Bath Remodeling 2 05-13-2011 07:33 AM
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 09:57 AM
