Going From Carpet To Hardwood, Is My Subfloor Sufficient? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2018, 02:25 PM   #1
Rewards Points: 8
Going from carpet to hardwood, is my subfloor sufficient?
Hi,
I'm planning on removing some carpet and replacing it with 3/4" hardwood flooring. The manual says the minimum subfloor thickness should be 5/8", but I only have 1/2" plywood under the carpet. The floor joists are 24" OC. Can I get away with installing the hardwood as is, assuming the subfloor is solid, or is this not enough support long term (and what should I do in this case?)?
linucksdiychat is offline   Reply With Quote
Old 03-19-2018, 02:30 PM   #2
Re: Going from carpet to hardwood, is my subfloor sufficient?
I have put down hardwoods in my houses. I roll out 30 lb tar paper and nail them down. I haven't had any issues with any of my floors in 20 years. I also make sure to let them acclimate for 2-3 weeks in the room they will be in as well.
Sent from my SM-N920P using Tapatalk
Jamie100 is offline   Reply With Quote
Old 03-19-2018, 02:42 PM   #3
Rewards Points: 8
The instructions with my flooring mentioned Aquabar B as an option, so I grabbed a roll of that stuff (I assume it's similar to the felt paper). So do you think the thinner 1/2" plywood can support the wood flooring with no problems?
Old 03-19-2018, 02:54 PM   #4
I do believe you would be fine without it but if need be, you could add a qtr inch plywood but I would definitely glue and screw it down good to prevent squeaking for sure. I have always only used tar paper. The stuff you are referring to is usually used as a sound dampener. I'm sure some others will come along soon and give theri input as well. I have laid tons of feet of solid oak hardwood and bamboo with no problems using my method though.
Old 03-19-2018, 03:04 PM   #5
Rewards Points: 4,170
I would think the call for 5/8" minimum likely assumed 16" OC structure. I would not install without calling the manufacturer and getting their sign-off.
Additionally, I would not put 1/4" plywood anywhere in the sandwich. I would either add another 1/2" or rip out what's there to install 3/4" if that suffices.
stick\shift is offline   Reply With Quote
Old 03-19-2018, 03:05 PM   #6
Rewards Points: 8
Call the manufacturer? Didn't think of that, thanks!
Tags
carpet , hardwood , subfloor
Carpet or hardwood cgrein Flooring 24 10-25-2016 12:28 AM
Cleaning Hardwood Floors after Ripping Out Carpet banzzy Flooring 3 02-14-2014 08:16 PM
Switching from carpet to hardwood on stairs Bugman1400 Flooring 5 12-29-2013 09:24 AM
From Carpet to Engineered Hardwood in a Weekend MisterPG Project Showcase 14 02-23-2011 01:48 PM
Carpet on hardwood floor, threshold hoozgrunt Flooring 1 07-15-2009 09:53 AM
