Glued Carpet Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 08-02-2015, 07:21 AM   #1
Rewards Points: 2
I have a roll of carpet about 6' 9" wide and 73' long that I plan to install in a room where there already is some old carpet glued down. I already know I need to get the old carpet out, clean up the old glue, etc. One of my questions is, should I be using carpet seam tape on the seams it I'm gluing it? And what would the best way be about installing the carpet?
jf5264835 is offline   Reply With Quote
Old 08-02-2015, 03:19 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
You don't need seam tape on glue direct carpet. Lay it all out dry and cut the seam. Then lay back the sides and glue the seam area first. Lay one side of the seam in the glue and put a small bead of latex seam sealer along one side of the seam backing and carefully lay the other side in. Then fold the rest of it back and do the same.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-02-2015, 07:42 PM   #3
Rewards Points: 4,422
Never just glue down a carpet seam, either tape it or stitch it.
ron45 is online now   Reply With Quote
Old 08-02-2015, 09:45 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
Why do you say that Ron? This is a glue down installation, not a conventional one with pad and tackless.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-04-2015, 08:25 PM   #5
I use to ask that same question Jazman.
Seams need to be tight but match, they also must hold.
I found this out when I had to redo a carpet in a hotel dining room. A lesson learned the hard way.
Black carpet pad glued down cmp61666 Flooring 2 12-29-2013 05:06 PM
Fixing squeaky/loud subflooring during carpet installation thunderbry Flooring 6 05-10-2012 04:01 PM
Problem with carpet glued to asbestos tile and want to replace... bobcaryh Flooring 7 11-29-2011 12:15 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
