Glue For Vinyl Stair Nose And For Molding On Concrete? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2017, 02:11 PM   #1
Rewards Points: 22
Question
Glue for vinyl stair nose and for molding on concrete?
hi all,
I have vinyl planks for floating floor and glued stairs
I replace carpet to it.
costco 4mm reclaimed-walnut-luxury-vinyl-plank/
I'm trying to sort out which adhesive to get for those applications:
1. glue stair nose to vinyl planks
2. glue 4in1 molding example to concrete floor for transition to tiles (about 5 mm raise) and to patio door frame
3. glue vinyl planks to "wood" stairs
so far I narrow down to those adhesives:
1. bostik best - not sure it's enough for concrete and stair nose, but should be good for stairs planks
2. Liquid Nails Fuze It - description looks good for concrete and stair nose
3. Loctite pl premium 3x - many like it, but I'm not sure it will work for all my cases
As I DIY the cure time isn't so important for me, but long time reliability / strength
Thanks for the help.
Mike
mikek753 is offline   Reply With Quote
