Glue Or Nail Laminate Onto Stair As A Riser? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2018, 10:49 AM   #1
Rewards Points: 50
Glue or nail laminate onto stair as a riser?
So I have decided to remove carpet and put laminate on the stair riser where that ugly carpet is on the top stair riser. Should I be nailing or glueing it some how? Any advice for this?
Glue or nail laminate onto stair as a riser?-5f057873-00bd-43ee-8920-254b8654f533_1517158116094.jpg
RTibs is offline   Reply With Quote
Old 01-28-2018, 12:05 PM   #2
JUSTA MEMBER
Rewards Points: 4,030
Re: Glue or nail laminate onto stair as a riser?
You want the laminate riser solidly affixed somehow.
If you don't it has a potential to trip someone on this step.
I don't know about you, but I sure do not like to trip on stairs, that sudden stop really hurts.
After you get the carpet removed see what you have for a riser, and attach the laminate using whatever the manufacturer advises .
ED
de-nagorg is online now   Reply With Quote
Old 01-28-2018, 12:11 PM   #3
Rewards Points: 50
Here is a photo of what is behind the carpet. I can either nail the laminate or glue the laminate I am just looking for some advice as to what is better? The manufacturer does not have any recommendation for stair risers on the packaging.
Glue or nail laminate onto stair as a riser?-6ee25f25-e954-4971-9f97-a490524f5d3a_1517163067124.jpg
Old 01-28-2018, 12:34 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 4,260
Use Fuze-it adhesive to glue it to the riser. How are you planning on addressing the nosing?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-28-2018, 01:08 PM   #5
JUSTA MEMBER
Any adhesive made for construction work will suffice, liquid nails, fuze-it, etc.
My preferred choice is PL Construction adhesive, it sticks well, and is hard to break the bond.
Just use it sparingly, and use a stiff plastic card to spread it thin.
An old credit card works well, as does an ice scraper .
ED
Old 01-28-2018, 03:26 PM   #6
Rewards Points: 17,912
Got a mess there, your missing a landing tread at the top step.
https://www.homedepot.com/p/Bruce-Gu...FY-0swodnckEUQ
The issue of using laminate on stairs and second floors has been talked about hundreds of times on this site and any other DIY site with all the real flooring guys agreeing it's not a great idea.
The flooring has to have room to expand and contract.
There's going to be a trip hazard at the nose of the steps.
Going to be tricky trying to cut those risers to fit and not have any gaps with no good way to fill them in.
If I "had" to do the job I'd glue them using a caulking gun leaving it at least 2" from the edges and spread it out with a 1/2" toothed trowel so the glue will smoosh out flat and not leave humps.
Nail, Glue, or Float Engineer Wood Flooring peterll Flooring 3 11-02-2014 02:32 PM
8" Wide Plank Hardwood... Nail and Glue ??? Paddy222 Flooring 5 06-08-2012 01:57 PM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 08:16 AM
Stair riser protection question JLam Carpentry 3 09-11-2006 04:28 PM
