Getting Ready To Lay Bamboo Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 02:37 PM   #1
Getting ready to lay bamboo floors
i was wondering if anyone could give me advice on which type of urethane adhesive to use. I see many types and so many price ranges. I have been leaning toward Bostik.... but what I am looking for is something with a bit of flex in it. The hardwood floor will be installed in the dining room, office, small hallway, and second bedroom, Now the tricky part. we are planning on using 16 x 16 ceramic tiles in the kitchen with a hardwood band all the way around.
is there a product that can be used on ceramic and bamboo?
how do we raise the height of the ceramic to be level with the bamboo?
and since we are planning on putting an underlayment down under the ceramic, do i need to scrape all the spots of glue that were remaining from before?
and when installing the hardwood up against the ceramic what is the best way to trim the tongue off without ripping the board
I know so many questions... so any help would be greatly appreciated
thanks
urbaneve is offline   Reply With Quote
Old 04-03-2013, 03:51 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
"underlayment under the ceramic" ?
sam floor is offline   Reply With Quote
Old 04-03-2013, 03:54 PM   #3
Rewards Points: 744
Adhesive
Bostik should be fine for the hardwood. Are you installing over concrete slab?
Is there a product that can be used on ceramic and bamboo?
Ceramic doesn't get glued down. It's set in a bed of thinset mortar.
With your concrete backerboard or Ditra mat.
What kind of underlayment do you speak of? Under the backerboard?
The best way and only way I would consider is by ripping the tongue off with a table saw.
Also, make sure to run Schluter edging between your tile and hardwood. Typically, the Schluter SCHIENE is used http://www.schluter.com/137.aspx
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
urbaneve (04-04-2013)
Old 04-04-2013, 08:18 AM   #4
we are on a cement slab and i was thinking that some type of moisture barrier needed to be applied unless the mortar will do that.
my other question is what type of Bostik product should we use? We do have some cracks in the cement floor, so i was thinking something that has a little bit of flex to it.... what do you think?
How to Recoat (Sandless Refinish) Hardwood Floors RhodesHardwood How To Guides 11 03-12-2014 11:42 PM
Bamboo floors, cracking sounds from staples, need fix! JasonU27 Flooring 0 12-18-2012 01:54 PM
Squeaky Floors-Wood Putty for Hardwood Floors that are Finished?Help HandyFrank Flooring 7 12-15-2012 07:37 AM
Wood Floors - old glue, something a little different scootermcrad Flooring 13 11-11-2012 06:36 AM
Unfinished Oak Floors starting_new Flooring 3 06-03-2012 08:58 AM
