Gap Size, Wood Floor To Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2017, 11:09 AM   #1
Rewards Points: 32
Smile
Gap Size, wood floor to tile?
Hi, I'm installing 6in engineered wood floor, and wondering the gap size I should leave as it will run parallel to tiled fireplace? I will frame around it fireplace with flooring. Thought I would use silicone caulk to fill gap.
Thank you so much for your help!
Jax2017 is offline   Reply With Quote
Old 07-21-2017, 05:06 PM   #2
Rewards Points: 17,936
Re: Gap Size, wood floor to tile?
Read the install directions on there website or right on the box.
Want a warranty on the flooring, follow there directions to a tee.
If so it's does not matter what anyone says on any web site.
Jax2017 (07-21-2017)
Old 07-21-2017, 05:59 PM   #3
Rewards Points: 32
Thank you. I have read the install paper, but it does not address this issue. Yes I agree, I am doing everything as specified to keep my warranty.
Old 07-21-2017, 06:25 PM   #4
Rewards Points: 32
So looking over install directions, it says to leave 1/2 inch over perimeter of room, which I have. Then it says " Also leave expansion space where the flooring will meets any vertical obstruction, such as cabinets, pipes, stairs or tiles. My tile is not a vertical obstruction, I've never seen wood flooring meet tile fireplace with 1/2 in gap.
Tags
engineered floor , gap size , tile and grout
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Transforming a tile floor to wood floor, Little help? ITTFIM1st Flooring 1 07-25-2011 08:51 PM
Wood baseboard and tile flooring Dave613 Flooring 1 06-02-2011 07:24 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
