Gap In Bathroom Tile Floor And Wall - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2018, 10:01 AM   #1
Rewards Points: 2
Gap in bathroom tile floor and wall
What is the best way to fix a gap between tile floor and wall. It is an uneven gap that ranges from 1/2" to 1 1/2" and it is also about 1/2"-1" deep. We are remodeling our bathroom and tore out the wall tile, there were two layers of tile from previous remodel which caused the gap between wall and floor. We are not planning to replace floor, but unsure of how to fix gap. We will be using a baseboard, but need something to sit it on.
pbach is offline   Reply With Quote
Old 11-08-2018, 10:14 AM   #2
JUSTA MEMBER
Rewards Points: 4,546
Re: Gap in bathroom tile floor and wall
It's going to be ugly whatever it is.
I would try to match the existing mortar color, and mortar the edges with it.
Troweling it smooth with a slight raised edge at the wall side, to channel any spilled water into the room, that will maybe stop any water from getting to the edge to possibly run under the baseboard, and rotting any flooring.
ED
de-nagorg is online now   Reply With Quote
Old 11-08-2018, 10:15 AM   #3
Rewards Points: 17,960
Using a real 1 x 6 as a baseboard with base cap molding on top and 3/4' 1/4 round at the base should work.
Old 11-08-2018, 10:20 AM   #4
JUSTA MEMBER
That would look OK.
ED
Old 11-08-2018, 12:00 PM   #5
Rewards Points: 98
I'd look for PVC or such. Wood touching a tile floor? Not in my book!
ChuckTin is offline   Reply With Quote
Old 11-08-2018, 12:30 PM   #6
retired framer
Rewards Points: 22,756
You will need a level line on the wall for the first board to go to. Or fill the gap with mortar.
