Flooring Spline Question - Flooring - DIY Chatroom Home Improvement Forum
Old 06-09-2018, 05:05 PM   #1
I am starting to put my 3/4" pre-finished hardwood down, but have an installation question. I would like continuous flooring from the hall to all the rooms. Based on the picture, the BLUE arrows indicate the main direction I am planning to install. Starting with the faint blue line and progressing forward. Now, the RED arrows indicate the secondary direction of install after installing a double spline. The back room in the center ( left RED arrow ) no issue as the double spline will be in the door threshold. The question arises in the room on the right, (right RED arrow ).
Can I use a long double spline the width of the room, gluing those two rows to the subfloor? Or should I measure the distance from where the spline would be to the back wall, calculate the starting piece as a multiple of the wood width, start on the back wall and hope my calculations come out ok?
I am leaning towards the spline, but would like the expertise here to validate, or change it. Thanks.
--Mark
mjf55 is offline   Reply With Quote
Old 06-09-2018, 07:57 PM   #2
Re: Flooring Spline Question
Well, I guess my google-fu was a little lacking before. I have found that the the proper way is to use a double spline, glue the spline into the wood, both sides. No need to glue to subfloor. Well that's my plan now.
Old 06-09-2018, 09:27 PM   #3
Rewards Points: 982
Yes that's what I was going to say. Long spline. Just be careful you don't push the board out of line when you nail it. No way you'll come out starting at the wall.
Marson is offline   Reply With Quote
Old 06-10-2018, 12:53 AM   #4
Marson, thank you for the confirmation.
Old 06-10-2018, 06:05 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 4,268
IF you are using cleats or staples to fasten the flooring, don't forget to nail/cleat/staple through the flooring starting your new direction. You will be fastening it through the newly installed spline. Otherwise it could cause a rise in the flooring along that run.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-10-2018, 10:06 AM   #6
chandler48, good point. I would have missed that. Thanks
wood flooring question willc86 Flooring 5 04-13-2016 10:07 AM
Laminate flooring underlay (foam) question J Thomas Flooring 2 04-08-2016 10:40 AM
Question on Acid Wash Flooring in Basement? Jim Ignatowski Flooring 0 07-23-2013 11:32 PM
Kitchen Flooring Question bcboy4ca Flooring 2 12-04-2012 10:51 PM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 04:52 PM
