Is This "flooring Saw" Any Good? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-06-2016, 06:31 PM   #1
Rewards Points: 60
Is this "flooring saw" any good?
I have a laminate floor to do at a family members house and it's about an hour drive. Don't really want to take my miter saw and table saw. Saw this flooring saw the other day at the box store and thinking about picking one up. It's small and says it does crosscut and rips. Looks like it would be perfect as long as it works OK. I know some all in one type tools are junk. So just wondering if anyone has experience with one of these? I know a few different brands make them.
http://www.amazon.com/gp/aw/d/B00J21...loL&ref=plSrch
ponch37300 is offline   Reply With Quote
Old 06-06-2016, 07:43 PM   #2
Rewards Points: 1,368
Re: Is this "flooring saw" any good?
Oddly enough just this morning I took an hour's drive (that turned into two hours due to rt 95 south being closed due to accident a mile before my exit!!!!!) to do a twelve bye fifteen Pergo floor for daughter's boyfriend. My compound sliding miter was already there
.....and he has a table saw...so I hauled zero tools....but having done a dozen or so rooms in the last year my only long rips were at an end where it is buried by molding anyway...so could be just cut with jig saw. Ron
ront02769 is offline   Reply With Quote
Old 06-06-2016, 08:14 PM   #3
Retired Moderator
Rewards Points: 7,174
I looked at those --I believe it will do what you want---but 140.00 for a one time use might not be the best idea---
I've installed laminate using a wood cutting box for cross cuts using a skill saw--
That material ruins blades, so I avoid using my miter saw---the big blades are expensive to replace--so I kill a 7 1/4" blade instead.
NJ Lumber Yards - good suppliers for decking? Quicksmoke Building & Construction 5 03-23-2012 01:50 PM
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 08:26 PM
Where can I find good contractor and building material suppliers? geordge Green Home Improvement 3 03-11-2009 11:11 AM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 09:27 AM
