Flooring Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 04-01-2016, 06:27 AM   #1
Rewards Points: 4
Flooring Problem
Hi there,
I am in Japan for a few weeks helping my friend in her house.
One of her problems is her hallway floor. It is a kind of fake parquet flooring approximately 1.5 to 2.5cm thick (0.59" to 0.98")
(see attached Photos)
As you can see from the photos there is a hole in the floor 30cm by 25cm or 11.8" by 9.8"
Many Japanese houses are built of wood as is this one, and the house is built on concrete pillars and there is a 55cm or 21.6" hole under the floor down to the ground.
So we either need to fix that hole or re floor the whole hall. (Probably the best option is to re floor the whole hall for as you can see on 1 of the photos, the flooring is in poor condition and looks terrible!)
Please could you give me any advice on how I might go about doing this. I'm completely new to this sort of thing! Also please could you give different-flooring options / materials. Wood of course, but also other possibilities, I'm struggling to figure out how to fix the hole when there is no floor underneath! (For information: There is no access underneath the house so all the work will have to be done above the hole not below!)
Thank you for any help or input you can give me
kind regards Gin
Flooring Problem-fake-parquet-flooring-2-.jpg   Flooring Problem-fake-parquet-flooring-3-.jpg   Flooring Problem-fake-parquet-flooring-4-.jpg   Flooring Problem-fake-parquet-flooring-5-.jpg
ginlane is offline   Reply With Quote
Old 04-01-2016, 06:47 AM   #2
Rewards Points: 3,702
Re: Flooring Problem
Are there structural members below outlining the opening?
Old 04-01-2016, 07:27 AM   #3
Rewards Points: 4
Hi there SeniorSitizen,
Thank you for getting back to me.
outlining the opening? do you mean around the edge of the hole?
If so, then yes on 1 side only! (See photo 2 near side)
Also there are joists Aprox 40mm by 40mm (1.5") running 25cm (9.8") apart holding the floor up.
Kind Regards Gin
Old 04-01-2016, 09:01 AM   #4
To provide a surface for repair patch, the joists will need to be scabbed onto until they extend out into the opening.
Whether to repair or replace the hall floor, sorry I can't help with that decision.
My flooring dilemma, what would you do? Joe Link Flooring 13 08-21-2014 08:54 PM
Gray Laminate Flooring ITSANSS Flooring 2 04-12-2014 07:58 AM
Old House Flooring Installation Advice rsvedin Flooring 2 03-15-2014 08:12 AM
Hardwood flooring - glue down installation - problem! Archeus Flooring 8 08-13-2013 08:43 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
