Flooring Options For Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 09:49 PM   #1
Rewards Points: 154
Flooring options for basement
Hi friends,
Thinking about redoing our basement and need some recommendations on what type of flooring to get. Right now it's a concrete slab. It flooded last year so we had to rip out the carpet and drywall. It is humid down there so looking to get a moisture friendly floor in laminate or open to any other options. We do not want to get carpet again.
What do you recommend?
Thanks in advance.
llckll is offline   Reply With Quote
Old 07-09-2012, 10:18 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
Personally, because of humidity and below grade, I would not put in any laminate, hardwood or carpeting.
The only thing that works in the basement is ceramic tiling. Yes, cold, but works the best. You can always put infloor heating to warm it up.
Good luck.
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 07-09-2012, 10:19 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by llckll
Hi friends,
Thanks in advance.
There aren't many laminates out there that are rated for below grade and even so there are ones rated I wouldn't recomend laminate or any engineered floor since you have flooding issues and humidity.
Can you find out what is causing flooding?
If that's not able to be fixed them my only suggestion is to raise the floor, sub pump then carpet. Or tile
JetSwet is offline   Reply With Quote
Old 07-09-2012, 10:47 PM   #4
Rewards Points: 154
There's a slight crack. The rain pipe was pointed straight down at it. I got an extension and pointed it away. No more flooding. We do have a subpump but the carpet soaked up all the water before it reached.
Old 07-12-2012, 03:01 PM   #5
I am going to install Floridatile HDP Berkshire in my basement. The look of wood but porcelain tile.
M Engineer is offline   Reply With Quote
Old 07-12-2012, 03:38 PM   #6
AGWhitehouse's Avatar
Rubber flooring is resilient, homogeneous in color, provides a thermal couple, is essentially water proof, and can be put down and taken up with extreme ease to allow for any cleanup efforts in the case of water spillage and/or seepage.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Canarywood1 (07-12-2012)
DuraFlex Epoxy Flooring Problem Amon Flooring 9 11-04-2013 01:47 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Hardwood flooring mess options WillK Flooring 3 07-15-2011 10:32 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Basement flooring options CooperChloe General DIY Discussions 3 01-25-2009 05:30 AM
