Flooring For Finished Basement? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2015, 09:00 PM   #1
Rewards Points: 38
Flooring for finished basement?
This winter I'm going to start finishing off the basement. Its dry as far as basements go. We really want carpet due to the 'warmth' of it because we live in Northern Michigan and it gets cold. Should we just use a vapor barrier /carpet pad combo underneath carpet, or an actual barrier, then pad then carpet .
lmholmes11 is offline   Reply With Quote
Old 10-08-2015, 10:26 PM   #2
Rewards Points: 2,288
We love our carpeted basement. Same thing in the basement as we have on the concrete of the ground level floor. Pad and carpet and I not sure what pad ( possibly foam ) but it sure feels good to my old feet.
I wouldn't allow a so called vapor barrier piece of plastic in my basement. Plastic is for storage bags and things of that nature that don't require fresh air.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
ron45 (10-09-2015)
Old 10-09-2015, 08:55 AM   #3
Rewards Points: 54
I'm installing vinyl planks in mine next week. Used Dricore subfloor
wetech is offline   Reply With Quote
The Following User Says Thank You to wetech For This Useful Post:
oh'mike (10-09-2015)
water under laminate flooring in basement ladygryffin Flooring 2 07-28-2012 12:49 PM
Best flooring option for basement flooring bristo_99 Flooring 2 11-09-2011 10:59 PM
basement flooring Master Brian Remodeling 4 05-20-2009 10:50 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
