Flooring Divider Between Uneven Areas - Flooring - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 10:52 AM   #1
Rewards Points: 1,062
Question
Flooring divider between uneven areas
I have several instances where two different types of flooring are bordering one another and almost always they are not even (e.g. 1/4" offset, give or take). A typical example is commercial flooring tiles on one side and regular ceramic tile on the other side or commercial flooring tile on one side and hardwood on the other.
Is it possible to custom calibrate a divider so that it exactly matches the offset? E.g. take an aluminum top of the divider and then add a different number or padding/shimming strips on either side to reflect the offset.
I hope no one comes back asking for pictures... This one should be a really common case scenario easy to visualize out of a simple word explanation.
Tags
divider , flooring
Uneven Basement Flooring Options FF1 Flooring 1 01-09-2012 07:11 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 10:44 PM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
Caulking Laminate Flooring margog85 Flooring 2 01-09-2010 08:57 AM
