Flooring Conundrum, In Need Of Ideas - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2014, 12:03 AM   #1
Flooring conundrum, in need of ideas
Hello!! My husband and I are new to DIYing our 1947 cape cod style house. But, for the first time, we've hit a "wall".
We pulled up the carpet in our dining room and are refinishing yet another section of hardwood maple flooring. These floors are beautiful. Seamless transition from one room to another...but with one exception.
Between the dining room and the bathroom (which we believe use to be a bedroom), there is a crudely placed painted 2x4 flush with the hardwoods. Perhaps there was a wall there at one point and not a door....I don't know.
So, without tearing the 2x4 out and replacing the wood (yeah...Over my head in skill and time), what would be a decent idea for a threshold/transition? He wants to put a chunk of wood there for less of a floor/door gap. I say paint. (I can't say I care about a gap).
Thanks for your help and time!
jahnmc is offline   Reply With Quote
Old 07-14-2014, 06:02 AM   #2
Retired Moderator
Rewards Points: 7,174
Removing the 2x4 and shimming--then adding a maple board would be the correct and easiest way---
However,if a 'quick fix' is all right with you---buy a 1/2" thick maple board and round over both long edges--and lay it over the top of the 2x4---
Old 07-14-2014, 09:23 AM   #3
Rewards Points: 18,384
Yes there was a wall there at one time.
They sell premade wooden thresholds, just cut to length and finish. Install with construction adhesive and a few long finish nails.
If that 2X sticks up to far it can be removed by making three cuts with an oscillating saw.
Cut the two ends and one cut in the middle and lift out with a flat bar from the middle.
The gap left can be filled with whatever thickness of wood needed to get it level with the hardwood.
rusty baker (07-14-2014)
Tags
hardwoods , quick fix , remodel , transition
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 07:24 PM
Need advice refinishing old flooring and blending with new unfinished flooring Daemian Raj Flooring 2 09-26-2012 09:46 PM
Throwing around some flooring ideas... BabsHoney Flooring 4 07-30-2012 10:31 AM
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
