Flooring Before Drywall - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 03-25-2017, 07:11 PM   #1
Rewards Points: 2
Hi everyone. I am in the process of building a home and decided to install vinyl plank flooring throughout the downstairs. I've never done this type of flooring before and I was wondering if it would be easier to install it before putting up the walls/framing since I won't have to cut around door jams etc. which I am worried I may mess up. I'm not too worried about getting the floors dirty/damaged because I was planning on covering them really well. Any advice would be appreciated!
nic1016 is offline   Reply With Quote
Old 03-26-2017, 07:29 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
Re: Flooring Before Drywall
I would not. Are you running base moulding throughout the home?
Sheetrock should go on (look up airtight drywall approach) and then your flooring.
Undercutting the trim around the doors is easy or just leave enough space under the trim before installation when you cut them.
jlhaslip likes this.
Old 03-26-2017, 09:24 AM   #3
jlhaslip's Avatar
Rewards Points: 708
^^^ what he said times 2
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-26-2017, 09:24 AM   #4
Rewards Points: 2
Hang drywall first. I'd then do as much work as possible before the floors go in. Window casing, hang and case doors, crown molding, paint, etc.
You can lay a piece of flooring under the door jambs as a spacer so you don't have to undercut it later. Then install flooring and base.
gary.bruzzese is offline   Reply With Quote
1910 Hardwood Flooring Question - Replacement Fisher1871 Flooring 0 03-21-2017 10:07 AM
How to repair a doorknob hole in drywall Sir MixAlot How To Guides 5 01-27-2015 07:17 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Any possible way to do flooring before drywall? tnis0612 Drywall & Plaster 4 02-10-2009 06:25 AM
