Flooring Before Or After Bathtub - Flooring - DIY Chatroom Home Improvement Forum
Old 02-08-2016, 10:46 AM   #1
Rewards Points: 86
Flooring Before or After Bathtub
My husband and I are remodeling the bathroom. I'm trying to figure out if we put in the bathtub, then the floor, or the floor then the bathtub. I'm reading online that when people do ceramic tile, they put the bathtub in, then tile the ceramic up to the bathtub. That's fine. It looks fine.
But what about other flooring? We're thinking of using Allure, and I hate the look of quarter round. Everybody wants to use quarter round to hide stuff. I can't stand it. Should we put in the Allure first, and put the bathtub over it (it's a 3 piece bath/shower), or should we put the bathtub in first and put the Allure up to it? If so, is there another way to do it besides using quarter round?
mrssp is offline   Reply With Quote
Old 02-08-2016, 11:56 AM   #2
Rewards Points: 144
What type of tub?Fiberglass? Install the tub and then the flooring.No corner bead but a nice bead of caulk.Some tubs require a mud bed under them.
What kind of Allure for the flooring.The planks would be a bad idea IMHO.
mako1 is offline   Reply With Quote
Old 02-08-2016, 03:27 PM   #3
Rewards Points: 86
Yes, a fiberglass tub. It's a 3 piece with the dome top.
Old 02-08-2016, 04:16 PM   #4
Rewards Points: 22
Is Allure laminate flooring? If so never use it in a wet area water will destroy it very fast. Ceramic or porcelin is the best. I agree with Mako caulk it.
frankrad is offline   Reply With Quote
Old 02-08-2016, 04:25 PM   #5
Rewards Points: 86
No, Allure tile is floating vinyl. You just peel the tape off the edges and stick one to the other.
I don't want ceramic because I HATE grout. It gets dirty. I would be obsessive about it and clean it with a toothbrush every week. Ain't nobody got time for that...
Old 02-08-2016, 04:46 PM   #6
Rewards Points: 22
Ok I used that in my waiting room for my business. It holds up well and you can mop it. The only down side is it will scratch if you drag something like a chair across it. But since you're using it in your bath it will be fine. Good luck!
Old 02-09-2016, 02:24 PM   #7
Rewards Points: 32
Ya just be careful cutting it so you have a even 1/8" gap or less, Then caulk it with a color matched acrylic caulk using the tape method(youtube it).
surfing_santa is offline   Reply With Quote
The Following User Says Thank You to surfing_santa For This Useful Post:
mrssp (02-09-2016)
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 07:24 PM
Cork Flooring ametty Flooring 9 11-01-2012 10:59 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
