Floor Tile On Walking Deck - Flooring - DIY Chatroom Home Improvement Forum
Old 05-28-2015, 05:24 PM   #1
Rewards Points: 850
floor tile on walking deck
ran across a outside deck with floor tiles on it, the material under it is a elastomeric roof coating, with the matting, the tiles on stuck down with thin set. the home owner has tried, and succeeded in a small area, to remove some of the tiles, about 6, but it seems they are really stuck good, especially the thin set. i figure the tile may not be that bad to get off, air chisel, but what about getting the thin set off the elastomeric paint, by the way its on plywood, if on concrete it would be able to be chipped off, but the plywood presents another problem, seeing as its flexible. suggestions.
hotrod351 is offline   Reply With Quote
Old 06-05-2015, 12:38 AM   #2
Rewards Points: 5,012
Other then replacing it, no..
ron45 is offline   Reply With Quote
Rooftop deck change: why is there a leak now? stripedbass Roofing/Siding 18 03-05-2015 08:11 PM
Rooftop deck change: why is there a leak now? stripedbass Carpentry 0 02-24-2015 04:32 PM
Pool Deck Cantilever nooneisathome Building & Construction 2 09-20-2014 10:13 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 11:15 AM
