Floor Leveler As Floor Surface - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 07:20 PM   #1
Floor leveler as floor surface
I am planning on leveling over a radiant heat mat I am installing in my bathroom on top of sub floor.
My choices after that are tile or epoxy (I have a friend that does epoxy in bathrooms). But I also heard that there was a floor leveler that can be stained and sealed as is. So it becomes the final floor. Must be pretty hard and hardy after it dries.
I am trying to find out what brand of floor leveler can be used in this way. Anybody know?
klantaff is offline   Reply With Quote
Old 07-18-2013, 07:24 PM   #2
Retired Moderator
Rewards Points: 7,174
I think you have been mislead---I never heard of a floor leveler that was tough enough for use as a wear surface----If you want to pursue that ,call the manufacturers and see what they say----but don't get your hopes up----Mike---
Old 07-21-2013, 12:27 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
...and, depending on how much "leveling" the floor really needs, your radiant can be more effective (react faster) in some areas than others.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
