Floor Level Prep - Flooring - DIY Chatroom Home Improvement Forum
Old 10-25-2014, 12:48 AM   #1
Rewards Points: 978
Question
Floor level prep
This project has been giving me headaches. so basically, i would like to put down new floors. originally i was going to glue down LVP, but the more i look at my floors the more i realize they are not flat at all. so my new plan now is to float engineered wood/lvp
so right now in one room i have vct glued down directly to the wood subfloor, 2nd story. it's fairly flat throughout the middle but in the 4 corners the floor bumps up quite a bit. i didn't take exact measurement but i would say a good 3/4 inch higher. now normally you can just sand down the bumps, but the vct tile and the adhesive probably have asbestos so i would like to lay the new floor on top of that without sanding it, etc.
so how do i make this floor flat? i been reading and the more i read the more confused i get. some say to use shingles, some say to use roofing felt, some say to emboss the whole floor, some say SLC, some say patch it with feather finish and feather it out gradually. i was thinking of laying down new plywood over the entire floor, and sand the plywood down where the bumps are underneath so it's level with the rest of the ply.
please help!
Floor level prep-img_20140920_194115_191.jpg   Floor level prep-img_20140920_194134_773.jpg   Floor level prep-img_20140920_194143_163.jpg
federer is offline   Reply With Quote
Old 10-25-2014, 09:56 PM   #2
Rewards Points: 978
ok let's rephrase the question. how do you make a vct tile floor flat without sanding it down?
Old 10-25-2014, 10:47 PM   #3
Rewards Points: 17,912
What's under that flooring?
Basement, crawlspace?
I'd be trying to figure out what caused that drop.
Not going to do any good to install a new floor over failing joist.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
federer (10-25-2014), JetSwet (10-30-2014)
Old 10-25-2014, 10:54 PM   #4
Rewards Points: 978
hey joe!
this is on 2nd floor. below this tile floor is downstairs where kitchen is. because of the tiles i cant really tell where the joists are...
Old 10-29-2014, 12:37 AM   #5
Rewards Points: 108
You need to put that tile down first because you have to make a plane surface over it. Applying plywood over whole room is the best option, it will help you to hide bumped flour correctly.
RobertCurry is offline   Reply With Quote
Old 10-29-2014, 01:40 PM   #6
Rewards Points: 978
what do you mean put the tile down first??
the issue with putting new ply down is the existing floor isnt flat so i need to fix that first
Old 10-29-2014, 03:10 PM   #7
Retired Moderator
Rewards Points: 7,174
Peal off the tiles in the high areas---they are asbestos based--so wet them down first--then peal them off with a bent scraper or whatever tool you have--
then see why the flooring is so much higher in the center.
federer (10-29-2014)
Old 10-29-2014, 03:54 PM   #8
Rewards Points: 978
yikes i was hoping you wouldnt say that. i think its because the joist is right below where the bump is, and maybe the nail has come loose
i mean its just in the 4 corners of the room...can i feather it out? or put new plywood down and sand the plywood to make it level with rest of plywood
Old 10-30-2014, 06:27 PM   #9
Retired Moderator
Have you tried adding some screws to the corners to see if the ply will pull down?
Your choice is to lower the high places or raise the low places---how you do that depend on the new floor covering--
federer (10-31-2014)
Old 10-31-2014, 02:09 AM   #10
Rewards Points: 978
no thats a good idea i need to try!
i am hoping to lower the high places because its mostly just in the corners.
the best choice is to have you come and do it
Old 10-31-2014, 06:14 AM   #11
Retired Moderator
I need a vacation---but I will be leaving the tools home when that happens.
Old 11-03-2014, 02:46 AM   #12
Rewards Points: 978
heh thats a good idea!
Old 11-08-2014, 06:54 PM   #13
Location: North-Shore Chicago, Northern NJ, Lower Outer Banks NC
Rewards Points: 4
This advice is 99% correct. Always take precautions when removing VCT.
If the tile is 9 inches square .. it is almost guaranteed to have asbestos in it.
If the tile is 12 inches square .. it's VERY unlikely to have asbestos in it.
Hope that helps with your uncertainty regarding pulling up the tiles.
Good luck with your project.
SaintlySins is offline   Reply With Quote
Best way to prep and paint a 42 foot exterior wall with 3 feet eaves? Homerepairguy Painting 4 09-01-2014 01:44 PM
Etching after prep tool? aodfan Concrete, Stone & Masonry 12 05-28-2013 08:25 AM
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 05:03 PM
Level 5 Smooth Wall + Priming fred s Drywall & Plaster 10 11-10-2010 04:54 PM
Sub-base/footer prep for pavers on canal rkh2619 General DIY Discussions 1 03-08-2009 08:39 PM
