Floor Joist Cross Bacing - Flooring - DIY Chatroom Home Improvement Forum
Old 10-29-2014, 11:23 AM   #1
Rewards Points: 463
Floor joist cross bacing
How far apart should cross bracing be on floor joists? Currently we are using the nail-less cross bracing, was thinking about adding more to strengthen up our floor.
cincinnati guy is offline   Reply With Quote
Old 10-29-2014, 11:37 AM   #2
Rewards Points: 17,912
Use blocking instead.
Old 10-30-2014, 10:47 AM   #3
Rewards Points: 24
Interested in this as well.
I have heard that blocking can squeak. Any comments?
As for distance between I was planning for every 2 feet. Is that overkill?
giannit is offline   Reply With Quote
Old 10-31-2014, 01:20 AM   #4
Rewards Points: 72
Most homes are built with joists that are 16 inches center to center, so the space between them is 14.5 inches. Residential building code requires the use of cross bracing or blocking for floor joists exceeding 2 inches by 12 inches. But for cross bracing, you can add the braces at 8-foot intervals.
emmyshaw is offline   Reply With Quote
Old 10-31-2014, 06:09 AM   #5
Rewards Points: 1,480
Continue with the X bracing. It's been known since back before Caesar the triangle excels in construction.
Old 10-31-2014, 08:51 AM   #6
Rewards Points: 24
Yes the space between joists is 14.5 in. But I am not sure I follow what you mean when you say "exceeding 2 inches by 12 inches"
Old 10-31-2014, 03:21 PM   #7
Rewards Points: 377
Add another 3/4" layer of osb with shiplags over the subfloor.
begal is offline   Reply With Quote
Attic joist cross beams & moving them Fox Building & Construction 11 04-02-2010 08:48 PM
Raising cross beam in A-frame attic Highland Lass Roofing/Siding 1 03-09-2010 03:30 PM
buying metal cross braces Lturgeon Building & Construction 8 09-01-2009 03:55 PM
removing joist cross bracing williemyers Building & Construction 1 08-11-2009 01:20 PM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 04:35 PM
