In-Floor Electric Heat Over Concrete Slab - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-08-2015, 06:49 PM   #16
Rewards Points: 5,012
Moisture, condensation, evaporation..
Here in this video starting at 1:21 he talks about it.
Question.
What happens when the moisture, condensation, etc., in the concrete is not able to evaporate.?
ron45 is offline   Reply With Quote
Old 10-09-2015, 09:46 AM   #17
Rewards Points: 85
I appreciate the video. But keep in mind I am not adding flooring to a basement I am adding flooring to a sun room that the slab is actually slightly above grade. The three concrete walls are above soil and outside. The current structure sits on top of the slab. This is not encased with little airflow like a basement. Here's a pic...
JohnC20 is offline   Reply With Quote
Pouring a concrete slab ponch37300 Concrete, Stone & Masonry 11 02-18-2015 06:33 PM
Build house on existing concrete slab troyman Building & Construction 6 04-21-2014 06:05 PM
Hardwood over concrete slab alessandrot Flooring 26 06-16-2012 11:05 AM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Laminate Floors over radiant heat in concrete slab richnsht Flooring 8 05-23-2009 01:16 PM
