Floor On A 4" Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2017, 10:50 AM   #1
Rewards Points: 88
Question
Floor on a 4" concrete slab
I will be installing a Floor on a 4" concrete slab
I'm planning on using PT 2X4's on the flat secured with Tapcon screws.
Insulation will go between the 2X4's
3/4" plywood for the subfloor.
Question is where does the poly go?
Sean
Sean McGill is offline   Reply With Quote
Old 06-19-2017, 04:18 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,260
Re: Floor on a 4" concrete slab
Have you done a moisture test on the concrete? Is it perfectly dry all the time? If not, why would you want to take a chance of rotting wood against wet concrete? What type floor are you planning? Is it inside, or outside? Is it in a living area or a patio?
The proper way to install a sleeper floor is to lay a moisture barrier on top of the concrete, then set your 2x4's upright to span across and fasten only at the ends into your banding board. The 3/4" Advantech will stabilize the sleepers as you apply glue and decking screws to it. If you insulate, use something like Roxul as it is waterproof, fireproof, vermin proof and mold proof. No nails through the vapor barrier.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-20-2017, 08:41 PM   #3
Rewards Points: 1,066
Roxul is nice, but you can use foam boards too. Chandler is on point about the rest of it.
One thing I'd add is if this is a garage that you're converting, then chances are that it's not level. You'll need to rip your sleepers (the boards resting on the ground) to create a level subfloor.
NotyeruncleBob is offline   Reply With Quote
Old 06-21-2017, 09:45 AM   #4
Rewards Points: 88
Sorry ... I also have this posted in
http://www.diychatroom.com/f19/floor...e-slab-513985/
It's hard to edit after a couple of days.
I found the Flooring section after I posted there.....
I will be sticking with that post
How to remove slope in a concrete slab aka join horizontal slabs TXKEVIN Concrete, Stone & Masonry 5 11-02-2016 08:46 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 07:40 PM
