Floating Peel-and-stick-backed Vinyl Plank Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-09-2015, 06:32 PM   #1
Rewards Points: 452
floating peel-and-stick-backed vinyl plank floor?
The slab in my 1960s rental home is rough, not smooth.
Peel and stick tile would most likely have very poor bonding.
What do you think about peel and stick resilient vinyl directly on a large sheet of Aquabar underlayment to make a floating floor?
I figure sticking vinyl planks to kraft/tar paper would eliminate any edges from popping up.
These 2mm lumber liquidators wood-look vinyl planks have the adhesive on the back, not on the edges like Allure or Armstrong Luxe.
I wonder if there will be shrinkage issues if 100% of the glue surface is stuck to the paper.
pman6 is offline   Reply With Quote
Old 06-09-2015, 07:58 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
The unevenness will telegraph thru the vinyl. Use a floor leveling compound.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Peel & Stick Vinyl Tiles rachel23 Flooring 13 10-16-2011 07:14 PM
Peel and stick vinyl flooring over absteos tile? Codchamp Flooring 3 07-17-2010 06:17 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
