Floating Or Glued Down Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-24-2015, 09:05 PM   #1
Rewards Points: 38
Floating or Glued Down Floor?
Hi,
I have engineered hardwood floors that came with my house when I bought it.
What is the easiest way to determine whether the floor is floating or glued down?
stonhenge is offline   Reply With Quote
Old 06-24-2015, 09:18 PM   #2
Rewards Points: 18,374
Why would you need to know?
Old 06-24-2015, 09:20 PM   #3
Rewards Points: 38
Because I am considering taking them out and I want to know how difficult it will be.
Old 06-24-2015, 09:37 PM   #4
Once again why?
What's wrong with it?
Only way to find out is to start taking it out.
Just trying to save you a ton of work.
What would you replace it with?
Old 06-24-2015, 09:40 PM   #5
Rewards Points: 38
Thanks for replying but I would prefer not to answer all these questions. For fun, let's just say I am going to take them out and replace them with marshmallows.
It's good general information for me to know anyway.
Hopefully someone is out there who can provide a simple method to verify how my floors were installed.
Thanks in advance for any help.
The Following User Says Thank You to stonhenge For This Useful Post:
MTN REMODEL LLC (06-25-2015)
Old 06-24-2015, 09:56 PM   #6
Rewards Points: 199
If there is quarter round take off a piece and see if you can pry up the first plank. Take the quarter round from a wall where the plank is running vertical to you (length wise). Don't pry it up all the way yet but you should be able to determine if it's glued. Floating floor doesn't offer any resistance. If there's no quarter round they might have installed the base board after the flooring. So take off a short run of baseboard and try prying.
I was just looking at a house that has about $5k worth of shiny new engineered wood in it. It was well installed but it was really ugly so I know why you'd want to replace it. The stuff was dark red. I've seen nice engineered flooring this wasn't it. I really hate dark floors in small rooms.
Arlo is offline   Reply With Quote
Old 06-24-2015, 10:01 PM   #7
Rewards Points: 38
Thanks much, Arlo. Sounds as if there is no shortcut - just have to take a little out to see, as Joe said as well.
Appreciate the help.
Old 06-25-2015, 06:41 AM   #8
craig11152's Avatar
Rewards Points: 1,220
do you have floor heat registers? Id start there if you do. Pull one up and see what you can figure out from the edge.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
Old 06-25-2015, 11:12 PM   #9
Rewards Points: 5,010
When walked on there is a very distinct sound for a floating floor, especially when it's laid over a thin foam sheet, which provides cushioning and sound-dampening.
The foam will also allow movement just by stepping on it, not so with glue.
ron45 is offline   Reply With Quote
Old 06-25-2015, 11:21 PM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 710
Yes ^^^^^^^^ Simplest method
MTN REMODEL LLC is online now   Reply With Quote
Floating floor to stair banister jmyers63 Flooring 4 01-29-2015 04:36 PM
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 06:43 PM
Mid span bridging lylsutherland Building & Construction 2 10-30-2012 12:10 AM
Musty smelling basement with a floating floor TSullivan Building & Construction 12 10-08-2012 03:38 PM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 03:10 PM
