Floating Floor Threshold Terminates Mid-run - Flooring - DIY Chatroom Home Improvement Forum
Old 01-26-2015, 04:25 AM   #1
Rewards Points: 12
Floating floor threshold terminates mid-run
Any good advice how to deal with the ends of the thresholds that are needed at the sill of a sliding door?
On either side of the door the new floorboards will tuck under the baseboards (with appropriate gap), but across the face of the door I need the thresholds. These should terminate at the door molding, and not run the length of the room (i.e., not run them past the door on either side), but this leaves the hard edges sticking up on either side of the door. Should I mitre a small pieces on the ends? Any other suggestions? Thanks in advance to all those with experience here.
Floating floor threshold terminates mid-run-img_2076.jpg   Floating floor threshold terminates mid-run-img_2077.jpg
CA_wolverine is offline   Reply With Quote
Old 01-27-2015, 12:43 AM   #2
Rewards Points: 4,424
What type of floor are you going to lay.?
ron45 is online now   Reply With Quote
Old 01-27-2015, 03:48 AM   #3
Rewards Points: 12
The new flooring is floating, click-lock, solid bamboo. In the photo you see the cork underlayment. Thanks.
Old 01-27-2015, 03:57 PM   #4
The size of the slider either 10' or 12' maybe a problem.?
What is the height difference between the cork flooring and the top of the threshold.?
The flooring should run length wise with the door.
If anything, I'm thinking matching quarter round.?
Tags
floating , hardwood
Floating Basement Walls jonhayden Building & Construction 15 12-16-2013 08:53 PM
Floating wall for basement pattyobrien3 Remodeling 11 11-07-2012 04:58 AM
Floating floor questions matt7125 Flooring 9 03-17-2011 04:30 PM
Potential buyer of my house withdrew interest-no bsmt floating walls gjw Carpentry 1 11-08-2010 11:37 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
