"Floating Entertainment Center - How High To Mount For Carpet Install - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2015, 01:55 PM   #1
Rewards Points: 12
"Floating Entertainment Center - How high to mount for carpet install
Looking to replace my entertainment center with one that mounts to the wall. Living room has wall to wall carpet which will be replaced within a year. I would like to do the floating entertainment center cabinet before the new carpet is installed. At a minimum, the bottom of the cabinet will be 3" above the carpet(on top of baseboard). I really would like the new wall to wall carpet to be installed under the cabinet in case the entertainment cabinet would be changed. Is there a minimum the installers would need in order to be able to stretch and trim against the wall under the cabinet?
tecboy is offline   Reply With Quote
Old 05-04-2015, 02:26 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 966
They need to be able to reach the wall to rub the carpet down and trim it, that is if they don't need to replace the tack strip.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-04-2015, 07:53 PM   #3
Rewards Points: 19,104
Makes no since to me to install a hanging entertainment center, but if I had to I would have the carpet installed before I built the cabinet.
Why would you not just build it and install the carpet around it?
rusty baker (05-04-2015)
Bathroom floor has crown (high spot) in center of floor, want to tile tunabreath Tiling, ceramics, marble 26 09-18-2012 07:47 PM
Pipes too high & too extended for new sink install Sascia17 Plumbing 6 11-21-2011 07:46 PM
Custom Entertainment Center Ideas - Help needed bjp2006 Carpentry 4 07-04-2011 07:50 AM
install -center sink toolbelt Tina Plumbing 2 07-11-2009 06:52 PM
High Hat Install On Old Circuit yellowrubiu Electrical 18 02-04-2009 06:49 PM
