Float Or Glue Down Engineered On Plywood Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-01-2015, 11:57 AM   #1
Rewards Points: 625
Float or glue down engineered on plywood subfloor?
I'm planning to install engineered wood (3/8", "random length" x 4 3/4" wide) on 3/4" plywood subfloor in 2nd floor bedrooms and hallways. If I understand correctly, floating click-lock install is supposed to be easier but requires an underlayment/moisture barrier i.e. "Floor Muffler" plus T-Moldings in all doorways as well as an Overlap Reducer or similar transition from hallway to top stair tread, which would give me a little trip bump right at the top of the stairs and in all doorways. ;( That said, I don't believe I've ever walked on a floating engineered click-lock floor and I'm also concerned about the not real "feel" or potential that even leveling the subfloor can still result in a bouncy floating floor.
Would you float or glue down and why?
a1481155 is offline   Reply With Quote
Old 07-01-2015, 11:15 PM   #2
Msradell's Avatar
Rewards Points: 980
I would consult the manufacturer of the flooring you are putting down and get their recommendations. They have a lot more experience than any of us do and can give you the pros and cons of any type of installation you are considering.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-02-2015, 05:16 AM   #3
Rewards Points: 625
Manufacturer offers instructions for both floating and glue down but doesn't recommend one over the other.
Old 07-02-2015, 09:57 AM   #4
Rewards Points: 93
What is the plywood going over? I am not sure about using a moisture barrier but I would see about a underlayment that they recommend. Call them.
7 VII 7 is offline   Reply With Quote
Old 07-03-2015, 11:45 AM   #5
Rewards Points: 625
...3/4" plywood subfloor in 2nd floor bedrooms and hallways.
I am sure! This is not my concern...I have already spoken to manufacturer. If I float, I'm using "Floor Muffler"; if I glue down, I don't believe underlayment is used.
Old 07-03-2015, 05:06 PM   #6
Rewards Points: 1,042
I personally would do the float method, simply because if a fix is needed down the road it will be a lot easier to accomplish.
Canarywood1 is offline   Reply With Quote
Old 07-03-2015, 09:28 PM   #7
Rewards Points: 9,422
I have done a grand total of one engineered wood floor, so I am hardly an expert, but I glued mine down. Owner of the flooring store recommended not floating it because it would be soft and possibly squeak when walked on.
SPS-1 is online now   Reply With Quote
Old 07-04-2015, 12:22 PM   #8
Rewards Points: 402
Half of your answer lies with your manufacturer. They offers general instructions for both floating and glue down options. However, float method is considered greatly as compared to the other. While it is easy to carry out, it saves your time. It is suggested to go for professional help before you proceed, else you may land up in a fix.
fortunerestore is offline   Reply With Quote
Old 07-10-2015, 07:38 AM   #9
Rewards Points: 625
Thanks, both excellent points! I'm turned off by the number of transitions the floating install requires i.e. in all doorways., etc. Anyone have thoughts on the following:
1) Notice no transitions in doorway from hall into master bedroom or closets. It's not my flooring but it is a floating click-lock install from same manufacturer, which also requires transition moldings in "all doorways, passageways or wall openings of 5' or less...as well as "floor spanning greater than 35 feet in length or width" and "floor areas interrupted by wall sections extending out of the wall, or floor areas which are not rectangular.".
2) How about stapling the floated flooring like this guy?:
Old 08-21-2015, 01:43 PM   #10
Rewards Points: 625
The 3/4" plywood subfloor is attached to the 1st floor ceiling joists, if that's what you mean.
I could be wrong but I believe moisture barriers are typically recommended for installs over concrete. Underlayment is a good question...For floating install, I already have the recommend underlayment "Floor Muffler Ultraseal", which is both a moisture barrier and underlayment. For glue-down install, no underlayment is required. However, a 3/8" - 1/2" layer of plywood "underlayment" attached to the sub-floor can be used to protect the sub-floor.
That being said, I have a staircase leading to the 2nd floor hallway, both of which have 3/8" parquet that will be removed. The plan is to install new 3/8" flooring in the hallway but NOT on the oak stair treads, but rather sand & refinish them, which will increase the rise by 3/8".
In the hallway, gluing down new 3/8" flooring on top of a 3/8" plywood underlayment, would increase the rise from the last stair tread to the top of new flooring stair nose, at the end of the hallway to 7 7/8". The rise below that will be 7 1/2" and the rest of the rises going down all appear to be 7 1/4" - 7/38".
Thoughts?
Old 08-21-2015, 07:39 PM   #11
I doubt the difference from 7 1/2" to 7 7/8" would be noticeable or a trip hazard.
Old 08-28-2015, 02:46 AM   #12
Rewards Points: 104
I'd go for the Floating because Floating a floor is easier to install than a glue down. There are less harmful fumes to breath when floating a floor. It has more give and so the plywood subfloor can have more small dips compared to a glue down engineered floor..
marks.fletchers is offline   Reply With Quote
Old 09-04-2015, 09:24 AM   #13
Rewards Points: 625
Thanks!
After consulting several local pro installers, although not ideal, it appears glue-down installation to the plywood sub floor without installing a plywood underlayment is the way to go, therefore no height difference issues.
Somethings I've learned...
If I didn't mind ALL of the required transitions at EVERY doorway AND in between the L-shaped hallway AND if I didn't have the staircase to deal with, I'd go with the easier, less expensive floating installation.
To me, all of the required transitions are bad enough but the deal breaker is the required "overlap stair nose" at the top of the staircase, which appears to create a trip hazard going down the stairs.
It appears, if I want my flooring, especially from the hallway to the top stair nose to be flush, my only option is a glue-down installation not floating.
Thoughts?
Old 09-08-2015, 09:05 AM   #14
Rewards Points: 224
if you watch both videos, seems like they nailed down for both. There's a suggestion that the floor was hard to nail at ~ 1:16-1:20 mark in the first one.
I"m in the same boat and considering just nailing it down with a cleat despite the manufacture suggestions.
vote4Pedro is offline   Reply With Quote
Old 09-10-2015, 04:23 PM   #15
Rewards Points: 625
Thanks!
If you re-watch it...again, I believe he was saying "the toughest part he said was the quarter round, which was solid bamboo...which they put up against the oak...very hard wood and hard to nail through...". He continues at 1:21 - 1:40 "...this is just a click-lock, it's a floating floor...better to me, it will expand...if it's nailed down or glued down, you're gonna have problems with it warping and this way it's free to move...".
I'm NOT floating this floor and nailing is not an option offered by the flooring manufacturer. The only other option is full spread glue-down. FWIW, The Floor Muffler Ultraseal underlayment that I bought for the floating offers a "double glue-down" option. However, Floor Muffler's web site says it "Provides superior moisture protection. Exceeds industry standards by over 700% (.3 lbs./1000 ft²/24 hours).".
However, in an article at NWFA it says "Don't install an impermeable moisture barrier over a wood subfloor. This could trap moisture in the subfloor, possibly causing rot and leading to health and structural problems." (http://www.hardwoodfloorsmag.com/ins...rlayments.html).
A couple questions:
1) Is Floor Muffler Ultraseal (I have call into them, waiting for reply) considered an impermeable moisture barrier that should not be installed over a plywood subfloor?
2) What are the benefits of a "double glue-down" install for engineered?
Engineered floating-click on plywood questions a1481155 Flooring 10 05-10-2016 03:13 PM
replacing plywood subfloor, please help crankbait09 Flooring 107 02-16-2015 03:12 PM
Plywood subfloor seam meets hardibacker seam (30 inches). tsayles Flooring 3 09-03-2012 09:58 PM
Engineered hardwood. HDF or plywood sub-layers? noone Flooring 0 08-23-2012 04:22 PM
Replacing Plywood SubFloor ... njchan Building & Construction 4 02-01-2010 05:57 PM
