Finding Non-flat Spots On Large Concret Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2015, 04:05 PM   #1
Rewards Points: 278
Finding non-flat spots on Large Concret Floor
Hi All,
Is there a simple way to find the non-flat spots on a large concrete floor?
The plan is to tile the floor afterward.
Thanks!
325_man is offline   Reply With Quote
Old 02-03-2015, 05:46 PM   #2
Rewards Points: 3,702
A large squeegee and water would give an initial indication where the high and low areas are. It looks as if 30" are available but if you would like larger you may need to build one with a straight edge and rubber weather stripping etc.
Old 02-03-2015, 06:54 PM   #3
Rewards Points: 1,042
An 8' straight edge comes to mind.
Canarywood1 is offline   Reply With Quote
Old 02-04-2015, 12:23 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 780
A straight edge 8-10 ft. long if you're alone. Make sure it's 100% straight. A string with a good helper works good too. They also sell laser devices for the job.
What kind of flooring will you be installing? You say tile, which to us means ceramic, right? What size, do you know yet? Tell us more.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-04-2015, 05:42 PM   #5
Rewards Points: 278
Originally Posted by JazMan
325, A straight edge 8-10 ft. long if you're alone. Make sure it's 100% straight. A string with a good helper works good too. They also sell laser devices for the job. What kind of flooring will you be installing? You say tile, which to us means ceramic, right? What size, do you know yet? Tell us more. Jaz
I have seen many different sizes. I'm thinking 12" x 12".
Old 02-05-2015, 01:19 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 780
So, how un flat is the floor? It needs to be in plane within " in 10' and 1/16" in 12". Bigger, glossy tiles require an even flatter substrate.
Jaz
Old 02-05-2015, 08:58 PM   #7
Rewards Points: 278
So, how un flat is the floor? It needs to be in plane within " in 10' and 1/16" in 12". Bigger, glossy tiles require an even flatter substrate. Jaz
So, using 8' straight edge, do I need to overlap the area as I check for flatness? By how much?
Old 02-05-2015, 09:24 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 780
Yes you have to overlap. Get some good knee pads and set the straight edge in every direction possible. Move it a foot or so to the next area. Keep doing this until you're satisfied. You should be able to get a good idea by just looking at first. Pay special attention near edges and around pipe and poles.
How old is the floor? Any floor drains. cracks? A good cheap straight edge is a #1 1x4" hardwood. 1x3 is too flimsy.
Jaz
Old 02-06-2015, 07:51 AM   #9
Rewards Points: 278
Yes you have to overlap. Get some good knee pads and set the straight edge in every direction possible. Move it a foot or so to the next area. Keep doing this until you're satisfied. You should be able to get a good idea by just looking at first. Pay special attention near edges and around pipe and poles. How old is the floor? Any floor drains. cracks? A good cheap straight edge is a #1 1x4" hardwood. 1x3 is too flimsy. Jaz
It's a 10 yrs old concrete basement floor. It has a couple 1/16" cracks that I plan to fill with concrete powder and spray them with water.
There is an area with pipes and sub-pump, but I won't be tiling that area. There is also a full bathroom in which I will be tiling.
There is also support pole in the middle of the basement, and I will be tiling around it.
The total basement area is about 1100 sqft.
Old 02-06-2015, 09:12 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 780
And that will do what? Waste of time, you're not painting the floor. If anything you need an uncoupling membrane or at least uncoupling mortar. And of course proper expansion joints at the perimeter and in the field.
Let us know the results when you get the straight edges and start checking the floor.
Jaz
Old 02-07-2015, 04:13 PM   #11
Rewards Points: 278
And that will do what? Waste of time, you're not painting the floor. If anything you need an uncoupling membrane or at least uncoupling mortar. And of course proper expansion joints at the perimeter and in the field. Let us know the results when you get the straight edges and start checking the floor. Jaz
Thanks, Jaz! I read more about the uncoupling membrane or uncoupling mortar. I'm thinking about uncoupling mortar only. I hope that would be sufficient. Are there additional steps I need to do for tiling over a control join as I have one in the basement? Thanks!
Large Basement Floor 325_man Building & Construction 2 12-30-2014 06:46 AM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 07:15 PM
Finding radiant floor tubes Thurman Plumbing 1 10-09-2009 10:33 AM
Best way to ensure flat floor between two cement board slabs? MeasureTwiceCutOnce Flooring 10 09-17-2008 12:20 AM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 10:36 PM
