Find High Point Of Kitchen Floor: - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2015, 08:32 PM   #16
Rewards Points: 2,906
I know this might sound like a dumb idea, but what about just loose laying tiles over the whole floor and seeing IF and where a problem might arise, and then just trying to fix those spots by spreading thin set to lessen any contour in the floor. I'm thinking just a trouble light placed on the floor in that spot would cast a shadow over any depression in the floor and show a huge mountain where any bump occurs. Worst case might be that by finding that bump, you may have located the high spot on the floor.
I know that seems like a lot of work, but so is spreading thin set all over the floor to not only get it flat, but horizontal, too.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 04-03-2015, 09:07 PM   #17
This might be another dumb idea, once you get that really long straight board to find the high spot, what about using 3/4 inch wide double sided tape to stick rough sand paper to the edge of that board and then sliding the board back and forth across the floor (kinda like a screeding motion) to see where the sand paper abrades the floor the most?
Those would be the high spots, wouldn't they?
Old 04-03-2015, 09:08 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 780
Nap,
Finding the one highest spot shouldn't be very hard. Using a level, whether regular or water level with hoses, would be great. But after that what is he gonna do? I know what he's thinking, but I don't think it's a good idea to build up as you go with thinset. That would be a royal mess.
Yes, I've seen the TLS leveling system, and others. They can really help until you get to a high spot. They're not gonna help you with high spots. But then we need the amount the floor is out of plane. Still waiting for the numbers.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 06:43 PM
Mid span bridging lylsutherland Building & Construction 2 10-30-2012 12:10 AM
Tiling kitchen. Floor uneven. Going crazy! allfy16 Tiling, ceramics, marble 1 10-20-2012 07:01 AM
What is the best way to level out kitchen floor? Womenonamisson Flooring 0 05-24-2011 12:47 PM
Sagging kitchen floor csaag Building & Construction 14 03-28-2009 07:30 PM
