Filling A Gap Between Above Floor Safe - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2015, 02:21 PM   #1
Rewards Points: 4
Filling a gap between above floor safe
I have a floor safe (previous owner) in a closet thats embedded in the concrete foundation, and I would like to level the floor there. Can I pour something directly over the safe door, and let it settle? The gap above the safe door varies due to the combination lock, but it's about 1-2". Or, I could take the safe door off, and put something flat there before filling the gap. Thanks
dan_dan is offline   Reply With Quote
Old 07-06-2015, 08:04 PM   #2
Rewards Points: 17,914
Why would you not want to leave the safe in place to use?
If your not going to use it then remove the whole thing and fix the subflooring.
Old 07-06-2015, 10:02 PM   #3
Rewards Points: 4
I would would like to level the surface for flooring, without taking a jackhammer to the slab.
Old 07-07-2015, 07:24 AM   #4
Rewards Points: 474
If you can remove the door fill it with redi-mix and continue on as planed
BrowneBearLLC is offline   Reply With Quote
Old 07-07-2015, 07:25 AM   #5
Rewards Points: 474
Make sure you throw some chicken bones in the bottom first
Tags
filler , flooring , foundation
filling existing concrete block cells Master Brian Concrete, Stone & Masonry 10 06-19-2015 03:28 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 11:56 AM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-27-2011 11:30 PM
Should air be flowing while filling air compressor? JGalovin Tools 10 03-14-2011 06:49 PM
Filling in old basement door entrance dedward Remodeling 4 07-28-2009 09:46 AM
