Filling A Bowl Shaped Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 08-14-2014, 09:50 PM   #1
Filling a bowl shaped basement
I'm trying to level the floor in my basement. its concrete and it's 21'x18' but it has a floor drain in it. the floor around the drain it 3.5" lower than the outside edge of the floor. I want to use drycore as a subfloor but the huge bowl shape is a problem. would just filling the depression with concrete be the best way to level off this floor?
Any help would be appreciated
Darkhorse393 is offline   Reply With Quote
Old 08-14-2014, 10:25 PM   #2
JUSTA MEMBER
Rewards Points: 4,050
That drain was installed for a reason.
I would find out WHY before I messed with it.
Then decide if I really need the floor level.
Then I would install ripped down floor joists, tapered to lie on the existing concrete, and be a flush level plain to install 3/4 ply flooring.
ED
de-nagorg is online now   Reply With Quote
Old 08-14-2014, 11:24 PM   #3
The basement used to flood years ago I guess, the drain goes to an old sump pump hole ( I poured water in it when I bought the house 5 years ago to see if they were connected) The basement has since been waterproofed and I haven't seen any water on the floor , in the drain, or in the sump pump hole in 5 years. Thanks for the advice, I was imagining pouring a ton of concrete through the window.
Old 08-16-2014, 07:53 AM   #4
Rewards Points: 996
this. and get a elf leveling laser level ($50 @ HD). this will make things much easier. and i would make an access panel for over the drain = you just never know when you would need to service/inspect that drain.
Fix'n it is offline   Reply With Quote
Basement Finishing Plan phoray Remodeling 3 12-20-2013 01:14 PM
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 08:27 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
