A Few Questions About Basement Bathroom Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2014, 01:31 PM   #1
Rewards Points: 22
A few questions about basement bathroom flooring
The cement floor in the basement has been cut out to lay pipes for plumbing a new bathroom. I have a couple questions about it.
1. After they refill the hole with cement and make it level with the rest of the floor, will the new concrete shrink as it dries? If so, is there something they can do to keep the new cement from sinking down below the level of the existing cement floor?
2. Before pouring the fresh cement into the hole, should the edges of the old cement be coated with a bonding agent so that it will adhere to the old cement?
The reason I'm asking is that if I lay some kind of tile on that floor, I don't want the grout lines or tiles to crack, if it can be prevented.
Barb
gma2rjc is offline   Reply With Quote
Old 01-19-2014, 11:54 AM   #2
Rewards Points: 996
i did the same thing, relocating a pipe, over a year ago. . i used regular sakrete with nothing else. the patch looks as if it were done last week.
did they "cut" the hole, or break it out ?
Fix'n it is offline   Reply With Quote
Old 01-19-2014, 03:38 PM   #3
Rewards Points: 22
Thanks Fix'n it.
They cut it with a saw. If yours has turned out alright and looks good, I won't worry about it.
Thanks again!
Old 01-19-2014, 08:00 PM   #4
Rewards Points: 996
i didn't cut mine with a saw. i busted it out. this makes a big difference. when the hole has smooth sides, the patch won't grab as well (if at all, idk). with a busted out hole, the sides are very rough and jagged. this gives a very good surface for the patch to grab onto.
know what i'm sayin ?
The Following User Says Thank You to Fix'n it For This Useful Post:
gma2rjc (01-19-2014)
Old 01-19-2014, 11:43 PM   #5
Rewards Points: 22
That makes sense. When the guys come to work on it again, I'll bring it up to them. Maybe I'll grab a bottle of the bonding agent at Lowe's tomorrow and ask them to use it.
Old 01-19-2014, 11:59 PM   #6
Dave Sal's Avatar
Rewards Points: 374
Bonding agent won't hurt so if I were you, I'd tell them that I wanted it used whether they thought it was necessary or not. It's your house and your job.
Dave Sal is online now   Reply With Quote
Old 01-20-2014, 12:29 AM   #7
Rewards Points: 22
Thanks Dave Sal. Do you think it would be necessary to add some rebar too, since the new cement will be up against the smooth cut cement?
Old 01-20-2014, 01:06 AM   #8
Dave Sal's Avatar
Rewards Points: 374
I just read a link on another forum about your exact question. One of the posters suggested renting a roto hammer drill and drilling holes every 16" on both sides. Add rebar dowels in each hole and this will lock the new concrete to the old. Seems that most don't think it's necessary and is overkill though.
The Following User Says Thank You to Dave Sal For This Useful Post:
gma2rjc (01-20-2014)
Old 01-20-2014, 07:26 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 612
If this were mine this is what I also would do, the rebar will be added security that the concrete will not sink at a later day. Or have them cut a ledge for the concrete to sit on. JMHO
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 01-20-2014, 09:29 PM   #10
Rewards Points: 996
the way i busted mine out, it left a sort of ledge. the edge of the hole, i shaped it in a rough V shape. the patch concrete fills around this, making a tongue and groove setup. once dried, the stone under it could be removed and it wouldn't effect the patch.
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 11:44 PM
Basement flooring questions momto4kids Flooring 1 10-15-2011 05:08 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
