Face Nail T&G - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2016, 05:19 PM   #1
Rewards Points: 6
Face nail T&G
Hello.
What nails are recommended for face nailing portions of a T&G reclaimed fir where the grooves are damaged?
RayRockford is offline   Reply With Quote
Old 07-27-2016, 06:06 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 802
Re: Face nail T&G
Is this the finished flooring? Makes a big difference. If it's the finished flooring, pre drill and use 6d finishing nails.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 07-27-2016, 06:38 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 984
Re: Face nail T&G
Why use the damaged pieces?
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 07-27-2016, 07:38 PM   #4
Rewards Points: 6
Re: Face nail T&G
Jazman it is going to be sanded and refinished.
Old 07-27-2016, 08:07 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 802
Re: Face nail T&G
Ok, good. My answer stands then. Tell us more. Is the wood 1x4 or 6", how about the subfloor? How old is the house, is the floor flat within specs?
Jaz
Old 07-27-2016, 11:23 PM   #6
Rewards Points: 6
Re: Face nail T&G
Thanks. It's an old house but with 3/4 inch plywood subfloors and beefed up joists with blocking screwed every 16 inches. 3/4" X 2.5" 20 foot fir planks.
Old 07-28-2016, 12:13 PM   #7
Davejss's Avatar
Rewards Points: 1,086
Re: Face nail T&G
I always blind nail through the tounge. When that's not possible I use an appropriately sized finish nail, set below flush, and filled with color matched filler. For 3/4" flooring I like 8d ring shank nails driven at opposing angles.
Trump 2020!
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
RayRockford (07-28-2016)
Tags
facenail , fir , reclaimed wood flooring , t&g
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Nail Question buildit45 Building & Construction 6 04-12-2012 11:54 PM
Code & Nail Plate & Wire on Face casnj Electrical 10 03-21-2012 01:56 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 07:56 AM
face nailing question.... shawn99 Flooring 3 12-20-2007 08:33 PM
