Extent Of SLC Pour At Threshold? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 01:18 PM   #1
Rewards Points: 28
Extent of SLC pour at threshold?
I am working on leveling the slab in rooms as needed, starting with my bathroom.
My question is: where should I set up the dam for the SLC pour at the threshold to the bathroom, considering the fact that all of the doors in the house lead into a central hallway, and that I can't level all the rooms and hall at once?
I haven't removed the door case, yet, so I put down a stick with some rough position numbers that you can see in the picture.
Thanks in advance for your thoughts!
Dave
lucifugens is offline   Reply With Quote
Replace threshold? thaKing Windows and Doors 4 07-17-2012 11:27 AM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
Should I chance removing this threshold? rosemonster Building & Construction 7 08-22-2010 09:34 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
