Extend Old Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-17-2018, 02:56 PM   #1
Rewards Points: 112
Extend old laminate flooring
I'm removing a 15 sqft closet in my basement. The closet has no flooring - need to extend existing floor. The rest of the room has laminate. The laminate is directly on the concrete (with thin pad on the bottom of the laminate, attached to the plank). There is no vapor barrier of any sort. I don't see mold on bottom of the piece I removed but it smells funky. Not much I can do there except replace the whole floor with vapor barrier which I'm not going to do at this time. I would consider it except that there's a pool table in this room, moving it would be a massive pain.
ANYWAY, the flooring is 15+ years old. Has no brand or numbers on it. Do I take a pull a sample of my floor and bring it to big box store? I know that even if I knew the brand/model/color, it's most likely out of production.
I read that I might have trouble finding matching tongue/groove and that I'll have to trim the new flooring before laying it down AND glue it? Sounds terrible. Any suggestions?
MattBK is offline   Reply With Quote
Old 10-17-2018, 03:09 PM   #2
Guapo
Rewards Points: 11,950
Re: Extend old laminate flooring
I wouldn't even attempt to match the type & color of the flooring & matching the tongue & grooves is worse. I would look for some rubberized squares to fill the gap. May I ask why you don't want the closet anymore?
Guap0_ is offline   Reply With Quote
Old 10-17-2018, 03:13 PM   #3
Rewards Points: 112
The closet is not in use and it's in a game room where we would like more room for games and stuff.
Old 10-17-2018, 03:34 PM   #4
Rewards Points: 4,768
Pool table on laminate.... You're lucky if that's not causing issues somewhere in the room with buckling or gapping.
stick\shift is online now   Reply With Quote
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
