Existing Laminate Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 03:25 PM   #1
existing laminate floor
i have a existing flowing laminate floor were some of the planks arebucking up and would like to know if i can remove some of them without damage to the good planks. my e-mail is [email protected]
denp is offline   Reply With Quote
Old 10-23-2011, 11:38 PM   #2
43 years in construction
Arkitexas's Avatar
Rewards Points: 77
Replacing damaged planks is a tricky process. Books with illustrated explainations would better show the several methods of repair. But first, be very sure the plank is actually warped.
The number ONE reason planks bow up is that the subfloor is not dead flat. Uneveness in the subfloor will always make planks bow up. If that is the case, any replacement effort will be in vain and you may end up with a bigger repair problem than you started with. Check the laminate floor manufacturer's published limits regarding subfloor flatness before you do any repair.
The SECOND most common reason for plank floor bowing is caused by improper mating of the interlocking joints. The joints must be correctly mated in a very specific way by inserting at an angle and dropping the plank flat. They cannot be driven horzontally. Joints must be kept absolutely free of obstructions.
Rarely do planks bow unless they have gotten wet.
Rick
Arkitexas is offline   Reply With Quote
Old 10-23-2011, 11:42 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Actually if the planks are buckling, there probably isn't any expansion gap around the edges. Check that first. That's the number one cause of failure and it can be fixed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-24-2011, 11:40 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Dennis, do you get tons of junk mail and spam from Nigeria promising you millions of $$$ and enhanced body parts?
There is a blue edit button in the bottom right corner of your post. I would suggest you use it to remove your email address.
Posting your email address on a public forum is really not a good idea.
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Water damage below laminate floor ediconu Flooring 10 01-23-2012 01:19 PM
Dryer exhaust damaging laminate floor? snowkilts Flooring 1 03-31-2011 09:15 PM
Laminate floor subfloor not level Jarrod23 Flooring 2 02-11-2011 03:40 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
