Engineered Hardwood With SPF Substrate - Flooring - DIY Chatroom Home Improvement Forum
Old 04-27-2018, 03:49 PM   #1
Rewards Points: 24
Engineered hardwood with SPF substrate
Hello,
I'm putting in new hardwood and have chosen engineered as it is going to be in the kitchen and want to avoid as many moisture-related issues as possible.
I'm looking at one made in Canada product for which I can get a pretty good deal. For our budget, it's this or a made in China Fuzion product. Originally I was planning on a ply substrate, but this made in Canada one has a substrate made of SPF stickers perpendicular to the wear layer (the blurb from the brochure is below). I haven't been able to find much info on this substrate method. Does anyone know how it compares to a plywood substrate, particularly in terms of stability? Their brochure shows it having a higher acceptable humidity range than their ply substrate product line. If you've installed it, was the installation ease any different than ply substrate?
The made in Canada product has a much thicker wear layer and is 3/4" compared to the 1/2" for the Fuzion one, so I'd like to go with it, but not if the SPF substrate is inferior to ply.
Thanks!
CmdrTom is offline   Reply With Quote
Engineered Hardwood Water Concerns bgit Flooring 8 04-15-2018 03:27 PM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Solid Hardwood Versus Engineered? jathas Flooring 10 01-19-2014 10:37 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
