Engineered Flooring Staple Size - Flooring - DIY Chatroom Home Improvement Forum
Old 12-11-2015, 10:20 AM   #1
Rewards Points: 53
Good Day,
I'm installing Lauzon Engineered Hardwood Flooring this weekend and thought I'd though a question out there last minute.
What size staple should I use? I'll narrow the opinions down (some info may be irrelevant but here incase it's needed)
  • I'm going to rent a Bostitch MIII stapler today and the local store only has 1-1/2" 15GA and 2" 15GA staples available.
  • 1000 ft2 of board
  • Lauzon requires the installation to be staples (not cleats or nails) but says 1-1/2" and 2" would work.
  • My subfloor is 5/8 T&G spruce (43 years old) with joists 16" on center (second floor - heated basement below)
  • Underlayment (http://www.fortifiber.com/aquabar_b.html) will be used and is approved by Lauzon
  • 90+% of installation will have boards running perpendicular to joists
  • The hardwood is 3/4" thick, two ply, top ply maple, bottom ply SPF with grain perpendicular to maple top
  • http://lauzonflooring.com/wp-content...red-Expert.pdf
Thanks!
Josh
trophywalleye is offline   Reply With Quote
Old 12-12-2015, 03:09 PM   #2
Tony_G's Avatar
Rewards Points: 48
It is recommended to use 2" staples for 3/4 inch hardwood, they go in at an angle of about 45 degrees, if you use the 1 1/2" ones you'll only have about 1/2 inch holding the hardwood to the subfloor.
Have fun with the project!
Tony_G is offline   Reply With Quote
engineered wood flooring nailer joshanah Flooring 3 06-04-2012 11:21 AM
Bowed Engineered Flooring Planks help! Flooring 4 04-25-2011 10:01 PM
Putting down engineered wood flooring - staple lumps mrsbtate Flooring 6 07-11-2010 07:20 PM
engineered wood flooring flugalbinder Flooring 1 05-06-2009 10:51 AM
Engineered Flooring Doorway Transitions? GaryD Flooring 1 12-21-2007 05:06 PM
