Electric Jamb Saw - Flooring - DIY Chatroom Home Improvement Forum
Old 06-12-2015, 12:25 PM   #1
Rewards Points: 294
Electric jamb saw
Has anyone trimmed the bottom of a door with one of these, just wandering if it was possible?
Mikeron is offline   Reply With Quote
Old 06-12-2015, 01:26 PM   #2
Retired Moderator
Rewards Points: 7,174
Poor idea--they are not designed to cut 1 3/8" --I think you will be better off removing the door and using a circular saw.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
joecaption (06-12-2015), Mikeron (06-12-2015), Yodaman (06-12-2015)
Old 06-12-2015, 01:41 PM   #3
Property Mgt/Maint
Rewards Points: 7,662
use your circ saw,
if you wrap the bottom of the door with painters tape, measure your length and mark on the tape, when you cut right thru the tape it will minimize the splinter tear out, also clamp on a straight edge for a guide,
[political signature removed]
Yodaman is online now   Reply With Quote
The Following 2 Users Say Thank You to Yodaman For This Useful Post:
Mikeron (06-12-2015), oh'mike (06-12-2015)
Old 06-12-2015, 06:05 PM   #4
Rewards Points: 2,906
Originally Posted by Yodaman View Post
use your circ saw,
I agree with Yodaman about using painter's tape to avoid splintering, but go one or two steps further:
First, set your circular saw's cut depth to just 1/8 of an inch or so, and just cut through the top layer of veneer.
Then, apply 2 layers of painter's tape to your straight edge, set your cut depth to just a bit more than the door thickness, make a second pass cutting all the way through the door this time.
The idea here is that by having the saw teeth enter and exit the veneer nearly parallel to the veneer, you minimize chipping of that veneer.
Also, by applying painter's tape to the straight edge on the second path, you effectively move the saw blade over a small fraction of an inch to prevent the blade teeth from chipping the veneer on the top side of the door.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
PVC to bottom of exterior door jamb jjrbus Carpentry 8 05-10-2013 02:35 PM
Trying to Repair Toro Electric Starter thimsyrag Landscaping & Lawn Care 0 08-01-2011 11:23 AM
electric easement samlock Building & Construction 7 04-05-2011 10:24 AM
Electric Forced Air Furncace Fisher HVAC 0 02-08-2011 08:24 AM
Reducer scribed to fit door jamb? Please Help!! joemontana16 Flooring 1 03-14-2010 11:47 AM
