Edges Cupping On Old Parquet Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 09:27 PM   #1
edges cupping on old parquet floor
I have a 60 year old oak parquet floor that I very recently had refinished.
The other day, a bottle of windex got knocked over on the floor. The lid was not on tight and it all leaked out. I caught it an hour or so later, but the floor was pretty soaked. The spot looks fine, but I noticed a short time later that the edges of the parquet pieces were very slightly raised. This was not the case before the windex incident.
They are up maybe 1/16th inch. I have a dehumidifier going in the room. Any chance that the boards with resume their former state when they dry completely??? I can't believe I did this.
mscrankypants is offline   Reply With Quote
Old 03-08-2012, 09:34 PM   #2
Retired Moderator
Rewards Points: 7,174
Quite likely the wood return to flat---keep the dehumidifier going---a little cupping might remain but most (if not all) should go away--
Old 03-08-2012, 09:44 PM   #3
Thanks! It's hard to believe that a short exposure to liquid could do that.
I didn't even immediately connect the cupping to the windex. I was worried that there was something else going on with the floor.
I kept looking and feeling the edges all over the room, but the raised edges was confined to one spot. It was then I remembered the windex.
This happened on Monday. Shouldn't it be dried out by now?
Carpet in the basement Packer Backer Flooring 17 11-30-2018 03:10 AM
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 06:09 PM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 09:59 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 02:08 PM
