Durock Outside Corner - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2014, 11:30 AM   #1
Rewards Points: 85
Durock outside corner
I am getting ready to put tile around my shower. This is new work and the tile will be going over Durock. The width of the bathroom is more than the length of the bathtub, due to where the rough in plumbing was put in. So, at the rear of my bathtub I have an outside corner and then a 20 inch wall to the next inside corner for the back wall of the bathroom. At that outside corner where the Durock meets the drywall I plan to use a steel drywall corner bead, mud the drywall side and just attach the Durock side then tile up to the corner and was wondering if there is a better way?
boilermaker27 is offline   Reply With Quote
Old 03-29-2014, 11:31 AM   #2
Rewards Points: 85
I meant Duroci/Drywall outside corner for the title
Old 03-29-2014, 04:00 PM   #3
Retired Moderator
Rewards Points: 7,174
You have an outside corner---one side drywall--the other side tile(durrock)
Use a metal or plastic corner bead there---keep it tight to the durrock or the tile will be raised---
Old 03-29-2014, 06:11 PM   #4
Rewards Points: 85
thanks
Durock / Drywall outside corner help Trucon01 Kitchen & Bath Remodeling 3 03-18-2013 06:24 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 11:08 PM
How to fill Durock board outside corner joints sukhenkoi Kitchen & Bath Remodeling 1 05-03-2011 11:22 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
